Civil Engineering Association Various Free Discussion CRSI DG 318-19 Protected by FileOpen
 deviationz
User ID: 2031
Threads: 51
Likes: 546 in 107 posts
Given Likes: 72
10-04-2020, 02:32 PM
Does anyone know how to decrypt a pdf that has been protected by FileOpen?
 temp1366
Senior Member
User ID: 85519
Threads: 80
Likes: 1,544 in 165 posts
Given Likes: 737
10-05-2020, 08:24 AM
Maybe this python script can help you:
[-] The following 2 users Like temp1366's post:2 users Like temp1366's post
  • Dell_Brett, oanm2000
 deviationz
User ID: 2031
Threads: 51
Given Likes: 72
10-07-2020, 05:13 PM
Ya, tried that with no luck.
 BennyP
Valuable Former Deputy
User ID: 842
Threads: 1,128
Likes: 30,986 in 4,091 posts
Given Likes: 612
10-08-2020, 05:24 AM
Why not to post the PDF so many users can try to help you ?
  • Dell_Brett, temp1366, jonygut, rami1976
 deviationz
User ID: 2031
Threads: 51
Given Likes: 72
10-08-2020, 10:16 PM
[-] The following 3 users Like deviationz's post:3 users Like deviationz's post
  • malc, temp1366, jonygut
 rami1976
User ID: 34597
Threads: 341
Likes: 9,523 in 1,137 posts
Given Likes: 1387
10-10-2020, 08:17 AM
I was unable to open the file in any pdf reader.
Searching google , the answer was to use adobe acrobat and install fileopen add on
after that trying to open the file :
"Document Access Denied: Publisher Permission Required
You have reached this page because of a failed attempt to open a file that was encrypted using the FileOpen document security software. The issue is not related to installation of the FileOpen Client (you were brought to this page by the FileOpen Client), but rather to the publisher of the document not having granted you access.
FileOpen Systems provides tools to publishers, but we do not decide who should be allowed to open documents. You must therefore contact that publisher and request permission to open the document. Please note the error message you received prior to being redirected to this page, and present the text of that error to the publisher.
If you do not know the identity of the publisher of the document you may contact FileOpen Systems to obtain that information, in that case please submit a technical support request here."
 aslam
Abu Dhabi
User ID: 64
Threads: 330
Likes: 7,707 in 755 posts
Given Likes: 2168
10-10-2020, 04:42 PM
My google search came to a conclusion that "Advanced pdf password recovery v1.31" could be a solution. I was not lucky to find the same.
Note: Newer version will not work.
 deviationz
User ID: 2031
Threads: 51
Given Likes: 72
10-10-2020, 07:42 PM
I have tried an older version of that program but doesn't work.
10-12-2020, 07:33 AM
Download this small program which run on command prompt:
Extract it.
Put your pdf file in [your desired directory]\bin (or same location as qpdf.exe)
Run cmd in [your desired directory]\bin ==> your will go to dos prompt command line.
x:\bin> qpdf --decrypt your_file.pdf  your_output_filename.pdf
x:\bin> exit.
Let's try to open  your_output_filename.pdf, there should not have any password protect.
Good luck.
 BennyP
User ID: 842
Threads: 1,128
Given Likes: 612
10-12-2020, 08:21 AM (This post was last modified: 10-12-2020, 08:21 AM by BennyP. Edit Reason: N/A )
First day i tried at least 20 programs dealling with PDF from my collection.
Used phyton scripts and so on too. Because was no good result i decided to not post about.
Now i tried the above but the result is
[Image: 21132432327831273636.gif]
  • aslam, temp1366, jonygut
Pages (2): 1 2 Next »
  [REQUEST] How can I open password protected .rar file ska51 5 10,288 07-24-2012, 05:22 PM
Last Post: ska51
