Civil Engineering Association Software Software Product Bentley Products PLAXIS 2D CONNECT Edition V20
 kwaja
Philippine
User ID: 176875
Threads: 1
Likes: 7 in 1 posts
Given Likes: 0
03-29-2020, 09:33 PM
The PLAXIS product team has unveiled PLAXIS 2D CONNECT Edition V20 is a powerful and user friendly finite element package intended for two-dimensional analysis of deformation and stability in geotechnical engineering and rock mechanics.
PLAXIS 2D CE V20.00.00 Release notes - Release: August 2019
New and improved features
Scripting Reference manual as a Jupyter notebook
- Easily learn Python-based remote scripting in PLAXIS with the new Scripting Reference manual. Sample scripts for each of the commands in PLAXIS 2D and 3D are offered in a Jupyter notebook. These samples can be run live in the software to see and understand what happens. You can also edit and rerun the samples and see the effect of your changes, offering a great way of learning-by-doing.
Others
- To improve the support for scripting, material properties can now be set to an invalid state without directly getting an error message. The calculation still needs a valid dataset;
- A new validate command for materials was added which checks every property at once;
- PLAXIS Soiltest now supports command line and remote scripting;
- the checks in the checkgeometry command have been extended. In addition, it is now also possible to execute this command from the calculation modes;
- added command for checking the calculation conditions. These conditions are now also checked when running the calculate command;
- added interactive documentation for Python scripting layer (Python Notebooks);
Fixed issues
- Interface pore pressure generation when adjacent soil uses Interpolate pore pressures is now been resolve;
- Display of plastic points could lead to an error. This is now resolved;
- Various meshing issues have been resolved;
- Other minor issues
The PLAXIS 2D and 3D CONNECT Edition now has a Scripting reference manual, learn-by-doing by changing and running live script examples.
PLAXIS Geotechnical Finite Element Analysis Software
Conquer any geotechnical project with confidence using PLAXIS. Design and perform advanced finite element analysis of soil and rock deformation and stability, as well as soil structure interaction and groundwater and heat flow. You will have what it takes to handle advanced constitutive models for the simulation of the nonlinear and time-dependent behavior of soils. Apply hydrostatic and nonhydrostatic pore pressures, model structures and the interaction between the structures and the soil, and take on projects of all types such as excavations, foundations, embankments, tunnels, mines, dredging, and more.
PLAXIS 2D is a powerful and user friendly finite element package intended for two-dimensional analysis of deformation and stability in geotechnical engineering and rock mechanics. PLAXIS is used worldwide by top engineering companies and institutions in the civil and geotechnical engineering industry. Applications range from excavations, embankment and foundations to tunnelling, mining and reservoir geomechanics.
PLAXIS is equipped with a broad range of advanced features to model a diverse range of geotechnical problems, all from within a single integrated software package.
PLAXIS uses predefined structural elements and loading types in a CAD-like environment. This empowers the user with fast and efficient model creation, allowing more time to interpret the results.
[-] The following 7 users Like kwaja's post:7 users Like kwaja's post
  • oanm2000, chitbk, mig21, tuanpecc1, bellerofonte, Batman07, eth0
 chukwuma
Nigeria
User ID: 54070
Threads: 6
Likes: 37 in 20 posts
Given Likes: 34
03-30-2020, 08:04 AM
Please can you mirror the link, the above link is only for premium users.
[-] The following 2 users Like chukwuma's post:2 users Like chukwuma's post
  • ghasa44, bellerofonte
 lisine
Vanuatu
User ID: 17927
Threads: 272
Likes: 11,709 in 1,305 posts
Given Likes: 4621
03-30-2020, 08:46 AM
PLAXIS 2D CONNECT Edition V20 | 764.2 mb
Not my upload.
[-] The following 21 users Like lisine's post:21 users Like lisine's post
  • daywalker, versiondemo, sabooryan, techno, chukwuma, 3fan, Dell_Brett, melkat, oanm2000, mig21, clerigo, tuanpecc1, PinkPant, Rainbow, zrilek, bellerofonte, chenamoy, temp1366, cace-01, monter, chitbk
 chukwuma
Nigeria
User ID: 54070
Threads: 6
Given Likes: 34
04-16-2020, 10:03 AM
The downloads stops halfway. Please can you mirror it on mediafile or other non restriction downloads websites.
 lisine
Vanuatu
User ID: 17927
Threads: 272
Given Likes: 4621
04-16-2020, 11:14 AM
[-] The following 20 users Like lisine's post:20 users Like lisine's post
  • chukwuma, cace-01, PinkPant, rami1976, blaze, Dell_Brett, zrilek, Batman07, chitbk, malc, gianniorlati, oanm2000, versiondemo, geomahesh, KhaLed-S.E, seawave, smode, yutt, spat, pousin
  STAAD.Pro CONNECT Edition Update 3 (21.03.00.146) RajaK 7 12,103 07-27-2024, 03:40 AM
  Bentley MicroStation CONNECT Edition 2023 poolmand 2 5,895 10-08-2023, 12:24 PM
  Bentley STAAD.Pro CONNECT Edition V22 kirankumarklk 12 21,966 07-05-2023, 07:52 AM
Last Post: Arigato
  Bentley.RCDC.Connect.Edition.11.02.00.200 kirankumarklk 0 4,784 04-02-2022, 11:14 AM
Last Post: kirankumarklk
  RCDC FE Connect Edition V4 Update 1 RajaK 1 6,715 03-28-2022, 06:28 AM
  Bentley OpenRail Designer CONNECT Edition 2021 poolmand 1 4,076 02-26-2022, 09:13 AM
  Bentley OpenRoads Designer CONNECT Edition 2021 poolmand 0 3,760 02-23-2022, 10:08 AM
