Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Books and Codes Request [REQUEST] SSPC-VIS 5/NACE VIS 9
[Request] SSPC-VIS 5/NACE VIS 9
 sabooryan
Senior Member
User ID: 163767
Threads: 77
Likes: 1,962 in 167 posts
Given Likes: 547
01-18-2019, 09:14 PM (This post was last modified: 01-19-2019, 01:26 AM by Dell_Brett. Edit Reason: increasing infos - COSMETIC CHANGES )
  • Article/eBook Full Name:
  • SSPC-VIS 5/NACE VIS 9
  • Author(s):
  • SSPC
  • Edition:
  • 1st
  • Publish Date:
  • 2005
  • ISBN:
  • 1889060577
  • Published By:
  • SSPC- NACE
  • Related Links:
  • Code:
Shows two uncoated, rusted steel surfaces (Conditions C and D) before and after wet abrasive blast cleaning. Photographs illustrate two degrees of cleaning (WAB 6 and WAB 10) for each initial condition, with additional photos that depict the appearance of light, moderate, and heavy flash rust after cleaning. Also contains a written guide to the use of reference photographs and additional explanatory notes. Cleanliness requirements for conditions depicted are defined by the joint SSPC/NACE surface preparation specifications for commercial (SP 6/NACE 3) and near-white blast cleaning (SP 10/NACE 2). Photos of commercial and near-white surfaces achieved by dry abrasive blast cleaning can be found in SSPC-VIS 1.
  [REQUEST] NACE SP0216-2016 Sacrificial Cathodic Protection of Reinforcing Steel in Atmosphericl tomtumx 0 1,206 11-06-2023, 11:59 AM
Last Post: tomtumx
