Civil Engineering Association eBooks Codes, Manual & Handbook ASME Boiler & Pressure Vessel Code 2013: Rules for Construction of Pressure Vessels:
 hodzicemir
Bosnia and Herzegovina
User ID: 36740
Threads: 15
Likes: 783 in 83 posts
Given Likes: 467
09-28-2015, 08:00 AM
ASME Boiler & Pressure Vessel Code 2013: Rules for Construction of Pressure Vessels: Division 1: 8
Author(s)/Editor(s): ASME | Size: 30 MB | Format: PDF | Quality: Unspecified | Publisher: ASME | Year: 2013 | pages: 822 | ISBN: 0791834727
Division 1 provides requirements applicable to the design, fabrication, inspection, testing, and certification of pressure vessels operating at either internal or external pressures exceeding 15 psig. Such vessels may be fired or unfired. This pressure may be obtained from an external source or by the application of heat from a direct or indirect source, or any combination thereof. Specific requirements apply to several classes of material used in pressure vessel construction, and also to fabrication methods such as welding, forging and brazing.
Division 1 contains mandatory and non-mandatory appendices detailing supplementary design criteria, nondestructive examination and inspection acceptance standards. Rules pertaining to the use of the single ASME certification mark with the U, UM and UV designators are also included.
Division 2 requirements on materials, design, and nondestructive examination are more rigorous than in Division 1; however, higher design stress intensify values are permitted. These rules may also apply to human occupancy pressure vessels typically in the diving industry. Rules pertaining to the use of the single ASME certification mark with the U2 and UV designators are also included.
Division 3 requirements are applicable to pressure vessels operating at either internal or external pressures generally above 10,000 psi. It does not establish maximum pressure limits for either Section VIII, Divisions 1 or 2, nor minimum pressure limits for this Division. Rules pertaining to the use of the single ASME certification mark with the U3 and UV3 designator are also included.
[-] The following 7 users Like hodzicemir's post:7 users Like hodzicemir's post
  • Dell_Brett, PinkPant, oanm2000, slowet, zrilek, Jackass, joker™
  NFPA 5000, Building Construction and Safety Code poolmand 1 2,111 01-03-2022, 01:01 PM
  API 620:2009 Design and Construction of Large, Welded, Low-pressure Storage Tanks ir_71 7 6,299 12-29-2021, 06:18 AM
Last Post: malee
  Egyptian Code of Practice for Steel Construction - LRFD 2008 AG.NAYEL 3 4,445 01-19-2016, 09:31 AM
Last Post: heogay43
  ASME BPVC Section VI - Recommended Rules for the Care and Operation of Heating Boiler hodzicemir 1 1,852 09-28-2015, 01:58 PM
Last Post: PinkPant
  ASME SECTION VII 2013 - Recommended Guidelines for the Care of Power Boilers by ASME hodzicemir 1 1,902 09-28-2015, 01:44 PM
Last Post: PinkPant
  ASME BPVC 2013 - Section VIII, Division 2: Alternative Rules hodzicemir 1 1,831 09-28-2015, 01:35 PM
Last Post: PinkPant
  2010 ASME BPVC Section IX welding code duazo2009 3 4,031 04-28-2015, 08:48 AM
Last Post: PinkPant
