Civil Engineering Association eBooks Structural Books Steel European Recommendations on the Stabilization of Steel Structures by Sandwich Panels
 agelos100
Member
User ID: 34967
Threads: 15
Likes: 173 in 18 posts
Given Likes: 378
09-27-2015, 06:45 AM
Author(s)/Editor(s): ECCS / CIB JOINT COMMITTEE | Size: 2.50 MB | Format: PDF | Quality: Original preprint | Publisher: CIB – International Council for Research and Innovation in Building and Construction | Year: 2013 | pages: 71 | ISBN: 9789063630812
[Image: 02824814875199070539.jpg]
This document gives information about the use of self-supporting sandwich panels as stabilizing elements for
single steel members such as beams or columns. The document extends the application range of
sandwich panels to construction class II according to EN 1993-1-3.
Sandwich panels provide stiffness against displacements in the plane of the panels and against rotation about the transverse axis of the panels. Thus, the sandwich panels may support the steel members against flexural, torsional and lateral buckling.
The effect of stabilization mainly depends on the properties, location and number of fastenings installed between the individual sandwich panels and between the sandwich panels and the supporting structures. This document introduces the evaluation of rotational stiffness and shear stiffness provided by individual sandwich panels that are installed in a wall or roof of a building. In these Recommendations, the use of information is limited in order to stabilize only single structural members.
Post Edited by moderator:
Removed dashes in ISBN number
[-] The following 17 users Like agelos100's post:17 users Like agelos100's post
  • cace-01, blaze, draluka, stosto6666, milova, slowet, cristi, malc, ykhackhack, dizz, zrilek, PinkPant, Dell_Brett, ruaumoko, oanm2000, K.Lee, kowheng
 ziggywas1
Semi Senior Member
User ID: 1224
Threads: 50
Likes: 1,478 in 124 posts
Given Likes: 637
09-27-2015, 07:21 AM
Direct link:
[-] The following 10 users Like ziggywas1's post:10 users Like ziggywas1's post
  • ting tsai huang, ykhackhack, zrilek, PinkPant, jcbv, Dell_Brett, oanm2000, Jackass, cace-01, kowheng
 PinkPant
Turkey
User ID: 25448
Threads: 66
Likes: 4,006 in 374 posts
Given Likes: 10354
01-28-2018, 02:04 PM
Use regular forum pass
PinkPant
[-] The following 21 users Like PinkPant's post:21 users Like PinkPant's post
  • jcbv, amindoxiti, Aviator, apocalipse, cace-01, pedzaquino, Trishu999, promo8, caifan, tomtumx, zrilek, blaze, subin91, oanm2000, Nita1391, gulilero, Dell_Brett, gianniorlati, cristi, munycamsec, kowheng
  ECCS - European Recommendations for the Design of Simple Joints in Steel Structures agelos100 0 1,765 05-14-2020, 09:19 AM
Last Post: agelos100
  ECCS No013 Recommendations for Safe Working During the Erection of Steel Structures david-smith 3 2,826 07-21-2016, 08:37 AM
Last Post: concreteok
  ECCS No125 - Buckling of Steel Shells, European Design Recommendations, Eurocode 3, Part 1-6 , 5th jcbv 6 3,480 07-09-2015, 03:09 PM
Last Post: monter
  European Recommendations for Steel Structures in Seismic Zones - ECCS54 peixoto 1 2,732 12-18-2013, 07:09 AM
  ECCS No021 european recommendations for the Design and Testing of Connections in Stee david-smith 1 1,938 11-16-2012, 09:16 AM
  European Recommendations for Slip Factors of Connections with H.S.F.G. Bolts Grunf 1 2,025 06-08-2012, 12:09 PM
Last Post: ssobhan
  European Recommendations for Sound Insulation in Multi-Storey Buildings ir_71 2 2,030 06-08-2012, 08:47 AM
Last Post: ssobhan
