Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) British Standards (Mega Collection - 14.5 GB)
 junaid
User ID: 402
Threads: 209
Likes: 8,170 in 732 posts
Given Likes: 983
06-07-2015, 09:30 AM (This post was last modified: 06-07-2015, 09:33 AM by junaid.)
Size: 14.5 GB | Format: PDF | Quality: Unspecified
Largest collection of British Standards till todate.
Thanks to original uploader.
[-] The following 52 users Like junaid's post:52 users Like junaid's post
  • freequo, titko, ssobhan, Dell_Brett, RyanRS, oanm2000, cace-01, mary, joker™, civilphongvan, jcbv, chenamoy, isurya, zrilek, cordoba123, jfjdm, allagui10, ibg0203, tomtumx, gianniorlati, concreteok, amareen2000, hodzicemir, highcivil, PinkPant, heogay43, Filko, lisine, hatkam, rusty, 3fan, LiviuM, chukwuma84, ashcivilea, shaker, dizz, serhioSPA, utan, nhim4mat2006, karthikeyans3d, bigone, blaze, f_slikken, araza023, st77bel, inge911, vinnunsam, monter, bridgeengineer, peixoto, alibouafia, aryan04
 concreteok
E-Book Moderator
Malaysia
User ID: 4764
Threads: 50
Likes: 4,962 in 637 posts
Given Likes: 3500
06-08-2015, 02:07 AM
any idea how to batch download the files? something popped up upon selecting some files but I doesn't read the language.
concrete solution advocate
 heogay43
Junior Member
France
User ID: 53842
Threads: 5
Likes: 48 in 8 posts
Given Likes: 127
06-08-2015, 07:44 AM
You can choose one document per time and click on the "CkYatb" with the arrow "download".
It works well for me.
[-] The following 4 users Like heogay43's post:4 users Like heogay43's post
  • LiviuM, cace-01, concreteok, bigone
 zrilek
Semi Senior Member
User ID: 3860
Threads: 12
Likes: 337 in 59 posts
Given Likes: 22010
06-08-2015, 08:49 AM
the site
is very friendly site and you can download whole folders by ticking empty square next to desired folder. in that way all folders can be downloaded at once. after ticking, click on button with arrow pointed downward.
hope this helps.
[-] The following 8 users Like zrilek's post:8 users Like zrilek's post
  • LiviuM, cace-01, junaid, concreteok, nhim4mat2006, bigone, araza023, K.Lee
 3fan
Romania
User ID: 29614
Threads: 161
Likes: 7,359 in 1,207 posts
Given Likes: 5546
06-08-2015, 01:56 PM
Or, you enter into one folder and select all documents you need same as email browser and then you press download.
Works for me too.
[-] The following 7 users Like 3fan's post:7 users Like 3fan's post
  • LiviuM, cace-01, junaid, concreteok, bigone, araza023, st77bel
 tomtumx
Semi Senior Member
User ID: 2851
Threads: 23
Likes: 725 in 124 posts
Given Likes: 770
06-09-2015, 12:08 AM (This post was last modified: 06-09-2015, 12:14 AM by tomtumx.)
If you select many folders or files and get a pop-up in red color, that means the selected stuffs are larger than 4 GB and you have to reduce the number of selected items (pressing shift + left mouse click).
The largest folder is BS EN (6.59 GB), I have to enter the folder and download in selected small groups. For other folders, I could download by selecting folder(s).
To select a group of files, left click on box of the first file, browse down to a targeted last file (screen response is slow), shift + left mouse click on the box of the last file, all the boxes within the range should now be selected. Press download button, if a red-color pop-up appears, reduce the selected files by browsing back to a new last file and shift+left mouse click again. You should get a new and smaller selected files. Then press download button again.
[-] The following 7 users Like tomtumx's post:7 users Like tomtumx's post
  • concreteok, zrilek, joker™, Dell_Brett, LiviuM, bigone, araza023
 zrilek
Semi Senior Member
User ID: 3860
Threads: 12
Given Likes: 22010
06-09-2015, 06:31 AM (This post was last modified: 06-09-2015, 06:47 AM by zrilek.)
In addition, you can open an account (and get 25 GB of space) and copy all 14.5 GB of files there. IMHO any kind of translator will be helpful. BTW, two folders are more than 4 GB, namely BS EN and BS EN ISO. Others can be downloaded at once.
[-] The following 5 users Like zrilek's post:5 users Like zrilek's post
  • Dell_Brett, LiviuM, bigone, araza023, concreteok
 LiviuM
Christmas Island
User ID: 430
Threads: 90
Likes: 3,228 in 559 posts
Given Likes: 1706
06-09-2015, 08:29 PM
Hello,
I've been struggling with this for more than 24h. (to make it work automatically)
I've tried several programming stuff (c# + webbrowser + webclient, c#+gekofx and a custom made chrome extension which failed miserably).
Finally I found a way in c# but it was ugly.
In the end I found JDownloader 2 Beta available here:
And you can use the first link, it will see all folders.
Sadly by default it works only for the first 500 files.
So spent another few hours decompiling the responsible plugin, attempting to install eclipse, jdk, ... to recompile the full application, without any luck.
Finally after trying all kind of constant string editors available around the web, for java compiled classes, dirty-joe saved the day Happy.
If you're up for some hacking Wink :
- install jdownloader 2 beta (warning it has 2 spywares simply decline the license agreement for those, the last 2 accept clicks).
- start dirty-joe, File->Open, look for CloudMailRuDecrypter.class, you'll find somewhere on your hdd, where JDownloader is installed. Like:
"C:\Users\ YourUserName \AppData\Local\JDownloader\jd\plugins\decrypter\CloudMailRuDecrypter.class"
- open it, go to Constant Pool, write 500 in active search textbox, click on:
0297: CONSTANT_Utf8: &sort=%7B%22type%22%3A%22name%22%2C%22order%22%3A%22asc%22%7D&offset=0&limit=500&api=2&build=
Click Edit item, replace 500 with let's say 10000, click Save, File->Save.
Thant's all. (24h vs. ~5min)
Or just replace it with the file already patched provided here:
In the end you should retrieve something like this:
Have fun
With so many doctors there's nobody sick in this world.
[-] The following 20 users Like LiviuM's post:20 users Like LiviuM's post
  • oanm2000, joker™, Dell_Brett, tomtumx, BennyP, junaid, herea, dizz, zrilek, RyanRS, 3fan, PinkPant, lisine, araza023, f_slikken, concreteok, abualamal, monter, bridgeengineer, vinnunsam
 hhstee
Malaysia
User ID: 167774
Threads: 0
Likes: 0 in 0 posts
Given Likes: 2
08-13-2015, 11:35 AM
Not that I need the codes that I am about to mention but why aren't there any BS8110 and BS 5950 in the collection ?
 PinkPant
Turkey
User ID: 25448
Threads: 66
Likes: 4,006 in 374 posts
Given Likes: 10354
08-13-2015, 12:47 PM
These codes are in the collection. You can find in BS subdirectory.
PinkPant
[-] The following 3 users Like PinkPant's post:3 users Like PinkPant's post
  • hhstee, junaid, oanm2000
Pages (3): 1 2 3 Next »
  British Standards Geotechncial Related elitvdis 1 3,060 03-24-2015, 09:28 AM
Last Post: hodzicemir
  A Collection of British Standards ssobhan 1 2,900 07-17-2014, 08:13 AM
  BS 5400: British code for the design and analysis of bridges jonamcivil 2 3,187 02-22-2013, 08:47 AM
Last Post: ssobhan
  British Standards for Draftings/Construction Drawings concreteok 1 3,327 02-07-2013, 11:18 AM
  British Standard EN Collection Grunf 10 8,015 11-17-2010, 12:10 PM
Last Post: Grunf
