Civil Engineering Association eBooks Codes, Manual & Handbook ACI ACI 212.3: Report on Chemical Admixtures for Concrete
 Mohammad6299
User ID: 42302
Threads: 261
Likes: 7,913 in 854 posts
Given Likes: 4212
08-05-2014, 04:30 PM (This post was last modified: 05-06-2023, 11:53 AM by Administrator.)
ACI 212.3R-10 - Report on Chemical Admixtures for Concrete
Author: ACI Committee 212 | Size: 1 MB | Format: PDF | Quality: Original preprint | Publisher: American Concrete Institute (ACI) | Year: 2010 | Pages: 61 | ISBN: 9780870314025, 0870314025
[Image: 35180195297510007924.jpg]
Chemical admixtures, which are primarily water-soluble substances, are discussed in detail and, in this report, are classified into 13 groups: airentraining; accelerating; water-reducing and set-retarding; admixtures for flowing concrete; admixtures for self-consolidating concrete; cold weather admixture systems; admixtures for very high-early-strength concrete; extended set control; shrinkage-reducing; corrosion-inhibiting; lithium; permeability-reducing; and miscellaneous. Chemical admixtures are used on a daily basis in the cast-in-place and precast concrete industries. Twelve categories of admixtures are described in detail as to type, current usage, and their effect on concrete in the plastic and hardened state. Their benefits and common usage are outlined.
Each category of admixture addresses the benefits obtainable with their use in a properly proportioned concrete mixture, types of batching systems, control measures, and test placements for mixture design verification. Mixture designs using multiple chemical admixtures have become more common. Their successful usage requires proper compatibility and, often, setting times and early strengths that are proper for the placing environment. The potential benefits are highlighted to all members of the concrete team, concrete contractor, concrete producer, admixture supplier, and testing personnel.
[-] The following 14 users Like Mohammad6299's post:14 users Like Mohammad6299's post
  • vardan, zrilek, amindoxiti, malc, subin91, bigone, ssobhan, Dell_Brett, ir_71, harsono, PinkPant, Jackass, gianniorlati, spat
Likes: 8,200 in 1,338 posts
05-06-2023, 11:52 AM
ACI PRC-212.3-16 Report on Chemical Admixtures for Concrete
Author(s)/Editor(s): ACI Committee 212 | Size: 1.78 MB| Format: PDF| Quality: Original preprint| Year: 2016| pages: 76 | ISBN: 9781942727804
[Image: 52887857766955293017.png]
This report reviews several categories and types of chemical admixtures and their use in unique concrete technologies. They are classified into 12 groups: air-entraining; normal, mid- and high-range water-reducing; accelerating; set-retarding; extended set-control; workability-retaining; viscosity- and rheology-modifying, shrinkage-reducing and shrinkage-compensating, and corrosion-inhibiting; lithium admixtures to reduce deleterious alkali-silica reaction; permeability-reducing; and miscellaneous.
Chemical admixtures are used on a daily basis in the cast-in-place and precast concrete industries. Mixture designs using multiple chemical admixtures are more common today. Their successful use requires compatibility, setting times, and early strengths that are appropriate to the placing environment.
Each category of admixture addresses common use and the potential benefits of a properly proportioned concrete mixture to various professionals, including the concrete contractor, concrete producer, and design professional. The sustainability of chemical admixtures and their role in sustainable construction is addressed. Finely divided mineral admixtures, such as fly ash or raw and processed natural pozzolans, are addressed in ACI 232.2R and ACI 232.1R, respectively.
Keywords: accelerating; admixture(s); admixture system; air-entraining; alkali-aggregate reaction; batching order; cold weather concrete; corrosion-inhibiting; extended set control; flowing concrete; high-range water-reducing admixture; mid-range water-reducing admixture; permeability-reducing admixtures; pervious concrete; self-consolidating concrete; set-retarding; rheology-modifying; shrinkage-reducing; water-reducing; viscosity-modifying; workability-retaining.
  • babakfeyzi, Umer.Aleem, PinkPant, milova
  [CivilEA Exclusive] ACI 228.1: Report on Methods for Estimating In-Place Concrete Strengt poolmand 0 1,249 12-14-2024, 01:23 PM
  [CivilEA Exclusive] ACI 334.3: Construction of Concrete Shells Using Inflatable Forms - Report poolmand 0 1,178 12-14-2024, 01:04 PM
  ACI E4: Chemical Admixtures for Concrete poolmand 0 1,279 08-28-2024, 07:35 AM
  [CivilEA Exclusive] ACI SP-354: Superplasticizers and Other Chemical Admixtures in Concrete - Conference poolmand 0 1,416 01-14-2024, 09:40 AM
  ACI 370: Report for the Design of Concrete Structures for Blast Effects er.shyams 1 2,373 05-09-2023, 09:25 AM
  ACI 445.1: Report on Torsion in Structural Concrete Mohammad6299 3 2,888 05-08-2023, 07:15 AM
  ACI 207.5: Report on Roller-Compacted Mass Concrete Mohammad6299 1 2,039 05-07-2023, 10:06 AM
