Civil Engineering Association eBooks Codes, Manual & Handbook AASHTO AASHTO - Standard Specifications for Structural Supports for Highway Signs, Luminaire
 jamildear4u
User ID: 5529
Threads: 87
Likes: 1,063 in 108 posts
Given Likes: 145
01-23-2012, 05:51 PM (This post was last modified: 03-02-2013, 02:10 AM by mybest.)
Structural Supports for Highway Signs, Luminaires, and Traffic Signals
5th Edition
Author: AASHTO | Size: 7.6 MB | Format: PDF | Quality: Original preprint | Publisher: AASHTO | Year: 2009 | pages: 268 | ISBN: 978-1-56051-399-5
[Image: 48809139598410961752.jpg]
The fifth edition of the Standard Specifications for Structural Supports for Highway Signs, Luminaires, and Traffic Signals incorporates recent work performed under the National Cooperative Highway Research Program (NCHRP) and state-sponsored research activities. NCHRP 20-07 Task 209 reviewed past research and recommended updates to the Specifications. Changes are primarily a result of NCHRP Report 469: Fatigue-Resistant Design of Cantilevered Signal, Sign, and Light Supports, and NCHRP Report 494: Structural Supports for Highway Signs, Luminaires and Traffic Signals.
Section 3, “Loads,” includes a metric conversion of the wind map presented in ASCE/SEI 7-05. The basic wind speed map is updated based on a new analysis of hurricane wind speeds and more detailed maps are included for hurricane-prone regions. Drag coefficients for multisided shapes are included which utilize a linear transition from a round to a multisided cross section.
Design guidelines for bending about the diagonal axis for rectangular steel sections are included in Section 5, “Steel Design.” The width-to-thickness ratios and the non-compact limit for stems of tees are also specified. Guidance is provided on the selection of base plate thickness because thicker base plates can dramatically increase fatigue life of the pole to base plate connection. Section 5 also includes updates to the anchor bolt material specifications used in traffic signal support structures; the design loads of double-nut and single-nut anchor bolt connections; allowable stresses in anchor bolts; specifications to proportion anchor bolt holes in the base plate; and guidance on anchor bolt tightening.
The scope of Section 11, “Fatigue Design,” is expanded to include non-cantilevered support structures and the associated fatigue importance factors. Vortex shedding response has been observed in tapered lighting poles often exciting second or third mode vibrations. Tapered poles are now required to be investigated for vortex shedding. Drag coefficients to be used in the calculation of vortex shedding, natural wind gusts, and truck induced wind gusts have been clarified, and additional guidance is provided as commentary for the selection of the fatigue importance category. Finally, the influence of unequal leg fillet welds on the fatigue performance has been included.
The Specifications are based on the allowable stress design methodology and are intended to address the usual structural supports. Requirements more stringent than those in the Specifications may be appropriate for atypical structural supports. The commentary is intended to provide background on some of the considerations contained in the Specifications; however it does not provide a complete historical background nor detailed discussions of the associated research studies. The Specifications and accompanying commentary do not replace sound engineering knowledge and judgment.
[-] The following 25 users Like jamildear4u's post:25 users Like jamildear4u's post
  • 3fan, slowet, chrono146, ziggywas1, gulilero, kowheng, lednar_ved, malc, Dell_Brett, ting tsai huang, foxxx2010, plngage, Albert, mahyarov, Ernest0, ssi3k, Kerry, blaze, apocalipse, engrirfan, shadabg, uetian19, vvvv, dinu69in, yekshakhsi
 mybest
Indonesia
User ID: 32155
Threads: 283
Likes: 3,957 in 566 posts
Given Likes: 686
03-02-2013, 02:10 AM (This post was last modified: 03-02-2013, 02:12 AM by mybest.)
[-] The following 10 users Like mybest's post:10 users Like mybest's post
  • Ultra Zone, shadabg, isurya, Jackass, Dell_Brett, mahyarov, uetian19, oanm2000, GMianG, milova
 lisine
Vanuatu
User ID: 17927
Threads: 272
Likes: 11,709 in 1,305 posts
Given Likes: 4621
10-21-2014, 09:23 AM
[-] The following 21 users Like lisine's post:21 users Like lisine's post
  • ahmednasr, amindoxiti, vvvv, Munykong, f_slikken, zrilek, karthikeyans3d, PinkPant, warlord1, ibg0203, vardan, seriousboy, oanm2000, Dell_Brett, er.shyams, subin91, GMianG, odiclas, sodapas, eldee, blaze
 civilfafa
Semi Senior Member
Iraq
User ID: 174183
Threads: 44
Likes: 304 in 50 posts
Given Likes: 459
10-05-2016, 09:57 AM
5th edition:
6th edition:
[-] The following 19 users Like civilfafa's post:19 users Like civilfafa's post
  • shaker, zrilek, Jackass, subin91, bridgeengineer, slowet, nickycruz, Dell_Brett, uncblue, oanm2000, jcbv, manzoor_quadri, cace-01, PinkPant, monter, deltalead, fretts08, adhikarig, kowheng
 concreteok
E-Book Moderator
Malaysia
User ID: 4764
Threads: 50
Likes: 4,962 in 637 posts
Given Likes: 3500
03-27-2020, 01:50 AM
concrete solution advocate
[-] The following 9 users Like concreteok's post:9 users Like concreteok's post
  • adhikarig, Dell_Brett, babakfeyzi, jcbv, gulilero, jcoronellr, Wijono, sodapas, oanm2000
04-01-2020, 12:01 AM
6th edition:
[-] The following 18 users Like kowheng's post:18 users Like kowheng's post
  • malc, raymelito, PinkPant, cace-01, blaze, zrilek, Dell_Brett, babakfeyzi, melekeen, rami1976, cargadory2k, apocalipse, jcbv, rendel_©, Wijono, CAMSECT, ralarcon, spat
01-25-2022, 10:57 AM (This post was last modified: 01-25-2022, 10:58 AM by poolmand.)
2015 Interim Revisions to
Standard specifications for structural supports for highway signs, luminaires, and traffic signals, 6th Edition
| Size: 8.94 MB| Format: PDF| Quality: Original preprint| Publisher: AASHTO| Year: 6th Edition, 2015| pages: 294 | ISBN: 1560516186 , 9781560516187
  • babakfeyzi, frank1972, Dell_Brett, oanm2000
  AASHTO LRFD Bridge Design Specifications 10th edition pezhmankhan 3 8,886 02-01-2025, 08:35 AM
  AASHTO M259: Standard Specification for Precast Reinforced Concrete Monolithic Box Se poolmand 1 3,250 09-23-2024, 10:15 AM
  AASHTO R69: Standard Practice for Determination of Long-Term Strength for Geosyntheti poolmand 0 2,904 01-15-2024, 09:01 AM
  AASHTO M351: Standard Specification for Cotton Duck Fabric Bridge Bearings, poolmand 0 2,895 01-15-2024, 08:42 AM
  AASHTO M270M/M270: Standard Specification for Structural Steel for Bridges poolmand 0 2,803 01-15-2024, 08:34 AM
  AASHTO M207M/M207: Standard Specification for Reinforced Concrete Elliptical Culver poolmand 0 2,690 01-08-2024, 05:25 AM
  AASHTO LRFD Bridge Design Guide Specifications for GFRP-Reinforced Concrete poolmand 0 2,925 08-30-2023, 08:45 AM
