Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS 4515-1:2009 Specification for welding of steel pipelines on land and offshore
 mybest
Indonesia
User ID: 32155
Threads: 283
Likes: 3,957 in 566 posts
Given Likes: 686
01-13-2012, 05:05 AM
BS 4515-1:2009 Specification for welding of steel pipelines on land and offshore. Carbon and carbon manganese steel pipelines
Size: 849 KB | Format: PDF | Quality: Original preprint | Year: 31 December 2008 | pages: 74 | ISBN: 978 0 580 56892 3
[Image: 81522588500865851286.png]
BS 4515-1:2009 specifies requirements for the welding of carbon, carbon manganese and low alloy steel pipelines with specified minimum yield strengths not exceeding 555 N/mm2 (grade L555 as specified in ISO 3183:2007 and BS EN 10208-2:1997 and designed in accordance with PD 8010-1 and PD 8010-2.
BS 4515-1 applies to pipes of outside diameter 21.0 mm and larger having a thickness of 3.0 mm or greater and is applicable to transmission pipelines for gases, liquids or slurries, both on land and offshore.
Information on hyperbaric welding and on brazing and aluminothermic welding of anode bonding leads, and recommendations for the welding of corrosion resistant alloy clad and lined pipelines, are provided.
This is a full revision of the standard, and introduces the following principal changes:
removal of references to BS EN 288-9, which has been withdrawn. Where appropriate, requirements from BS EN 288-9 have been incorporated in this standard
revision of Clause 8 on testing, qualification and approval of welding procedures
revision of Annex A on hyperbaric welding.
BS 4515-1 specifies:
Normative references
Terms and definitions, and abbreviations
Information and requirements to be approved and documented
Equipment
Welding process
Welding consumables
Testing, qualification and approval of welding procedures
Testing, qualification and approval of welders
Production welding
Inspection and testing of welds
Acceptance and rectification of welds.
BS 4515-1:2009 supersedes BS 4515-1:2004, which is withdrawn.
[-] The following 5 users Like mybest's post:5 users Like mybest's post
  • kowheng, malc, peixoto, Dell_Brett, NBZ1400
 arshiakh
User ID: 37777
Threads: 100
Likes: 3,224 in 617 posts
Given Likes: 214
02-21-2013, 01:59 PM
[-] The following 1 user Likes arshiakh's post:1 user Likes arshiakh's post
  • knrsa
 legend2611
Vietnam
User ID: 97786
Threads: 1
Likes: 1 in 1 posts
Given Likes: 5
07-17-2014, 02:11 AM
I CAN NOT GET THIS FILE , SOME ONE HELP ME UPDATE MIRROR LINK PLS :(
  BS 7973 Spacers and chairs for steel reinforcement and their specification ir_71 3 3,782 11-27-2019, 06:39 AM
  BS 4449:2005+A2:2009 Steel for the reinforcement of concrete — Weldable reinfor... portal61 4 4,087 09-16-2014, 12:20 PM
  BS 4449:1997+A1 Specification for Carbon steel bars for the reinforcement of concrete ir_71 3 3,936 05-15-2014, 07:52 AM
  BS4074:2000 Specification for steel trench struts chenamoy 0 1,885 12-02-2013, 03:46 PM
Last Post: chenamoy
  BS 6173:2009 Specification for installation and maintenance of gas-fired mybest 2 2,441 02-26-2013, 07:13 AM
Last Post: arshiakh
  BS 6798:2009 Specification for installation and maintenance of gas-fired boilers of r mybest 2 2,571 02-26-2013, 07:10 AM
Last Post: arshiakh
  BS8666-2000 (Specification for scheduling, dimensioning, bending and cutting of steel Learner 1 2,275 02-21-2013, 10:54 PM
Last Post: arshiakh
