Civil Engineering Association eBooks Geotechnical Engineering Foundation & Geotechnics in general Rockfill in Hydraulic Engineering
 ska51
User ID: 11535
Threads: 427
Likes: 9,406 in 1,251 posts
Given Likes: 4017
01-06-2012, 06:52 PM (This post was last modified: 01-06-2012, 06:56 PM by ska51.)
Rockfill in Hydraulic Engineering (Developments in Geotechnical Engineering)
Author: David Stephenson | Size: 6.60 MB | Format: PDF | Publisher: Elsevier Science Ltd (August 1979) | Year: 1979 | pages: 228 | ISBN: 0444418288 & 9780444418289
[Image: 17298081417271346353.jpg]
Book Description:
Rockfill is an inexpesive material which can be put to many uses in civil engineering, particularly in the field of hydraulic engineering, where its durability, weight, permeability, roughness and flexibility may all employed to advantage.
In this book Professor Stephenson presents the general theory for design of rockfill structures. He assembles and condenses into usable form much research literature on the flow through and over rockfill and the stability of rockfill subject to hydraulic forces. The theory is then applied to the design of such hydraulic works as dams, breakwaters, drainage and earth retaining structures.
An assessment of the properties of rockfill and its applications is accompained by an analysis of flow through rockfill and the theory applied to the design of retaining and protective works. Dam design including underwater construction using rockfill or gabions is described. The design of gabion retaining walls and revetments is covered, as well as the use of gabions for river works including groynes and channel linings. An introduction to coastal engineering accompanies sections on the design of breakwaters, revetments and shore protection, and the reader is also introduced to the theory of transport of rock in channels and by pipeline.
[Image: comments.png]
Password is needed only for mirror links.
"Downstream is Weaker"
[-] The following 10 users Like ska51's post:10 users Like ska51's post
  • malc, youceftli, OSHO, Dell_Brett, Jackass, kowheng, chatxxnoir, dede, tuanpecc1, zrilek
06-03-2012, 05:39 AM
PDF|RAR 6.84|6.41 MB
[-] The following 9 users Like kowheng's post:9 users Like kowheng's post
  • tuanpecc1, blaze, zrilek, Dell_Brett, Jackass, knrsa, lisine, shadabg, gato8015
Away  joker™
User ID: 10925
Threads: 92
Likes: 7,246 in 938 posts
Given Likes: 2426
06-29-2012, 04:30 PM
No limits to creativity
[-] The following 4 users Like joker™'s post:4 users Like joker™'s post
  • zrilek, 3fan, Dell_Brett, shadabg
08-11-2012, 07:53 AM
More Links :
[-] The following 3 users Like shadabg's post:3 users Like shadabg's post
  • cace-01, zrilek, oanm2000
 febo927
User ID: 23688
Threads: 105
Likes: 4,179 in 339 posts
Given Likes: 1279
07-12-2018, 01:45 PM
[-] The following 6 users Like febo927's post:6 users Like febo927's post
  • gulilero, oanm2000, zrilek, rami1976, shadabg, PinkPant
 rami1976
User ID: 34597
Threads: 341
Likes: 9,523 in 1,137 posts
Given Likes: 1387
07-12-2018, 08:22 PM
[-] The following 6 users Like rami1976's post:6 users Like rami1976's post
  • oanm2000, Dell_Brett, shadabg, emmi, mgdario, kowheng
  Concrete Face Rockfill Dams Design, Construction, and Performance: Proceedings of a S ELAHI1979 3 3,096 08-28-2012, 11:44 AM
Last Post: shadabg
