Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Books and Codes Request [REQUEST] Design of Portal Frame Buildings (4th Ed.)
[Request] Design of Portal Frame Buildings (4th Ed.)
 adams
User ID: 10887
Threads: 5
Likes: 193 in 28 posts
Given Likes: 590
Points:1,146 EP
10-13-2011, 12:23 AM
This great book has been revised, in line with the latest Australian codes. For more details continue reading below.
If anyone has a copy, please share:
Design of Portal Frame Buildings, 4th Edition
S. T. Woolcock, S. Kitipornchai, M. A. Bradford, G. A. Haddad
[Image: 72263647554679689200.jpg]
This book presents limit states design procedures for the design of portal frame buildings based on Australian standards.
Portal framed steel clad structures are the most common type of industrial buildings.
They find extensive use as industrial factory and warehouse structures, and as indoor sporting venues.
The major components of a portal frame building are a series of parallel portal shaped frames as the major framing elements.
Each frame is rigid, and resists horizontal wind forces and gravity loads in the plane of the frame by flexural action.
The new 4th edition has been almost completely rewritten to account for changes in the loading codes particularly the new wind code, the availability of new purlin and girt sections and ASI’s publication of new connection manuals.
New design capacity tables for horizontal SHS struts up to 400x16 Grade 450 SHS are included and design capacity tables for crane runway beams and monorails have been updated and expanded.
The information and design guidance on monorail cranes has been significantly expanded and design examples added.
A method of dealing with elongated local pressure patches is presented including patches with the new local pressure factor of 3.0.
There has also been the opportunity to correct previous errors and to generally refine and update the previous edition.
The book should prove of great assistance to practising engineers as well as students.
[-] The following 2 users Like adams's post:2 users Like adams's post
  • bashir999, oram
 oram
Saudi Arabia
User ID: 10555
Threads: 10
Likes: 121 in 60 posts
Given Likes: 595
Points:5,859 EP
06-03-2012, 06:40 AM
HI ADAMS,
PLEASE CHECK THIS LINK
[-] The following 6 users Like oram's post:6 users Like oram's post
  • blaze, zrilek, malc, gulilero, knrsa, terrorruban
 adams
User ID: 10887
Threads: 5
Given Likes: 590
Points:1,146 EP
06-23-2012, 02:18 AM
I am looking for the 4th Edition, not the older 3rd Edition.
  • david-smith, oram
 sandeepb
User ID: 33504
Threads: 16
Likes: 217 in 32 posts
Given Likes: 9
Points:1,729 EP
07-27-2019, 08:52 AM (This post was last modified: 07-29-2019, 01:17 AM by Dell_Brett. Edit Reason: FORUM BUG REMOVED )
Any one got 4th edition?
 malc
User ID: 30599
Threads: 66
Likes: 1,520 in 155 posts
Given Likes: 15191
Points:15,026 EP
09-12-2020, 03:22 AM
  • Article/eBook Full Name:
  • DESIGN OF PORTAL FRAME BUILDINGS INCLUDING CRANE RUNWAY BEAMS AND MONORAILS
  • Author(s):
  • Woolcock, S.T., Kitipornchai, S., Bradford, M.A. and Haddad, G.A.
  • Edition:
  • 4TH
  • Publish Date:
  • 2011
  • ISBN:
  • 9781921476266
  • Published By:
  • ASI 180 Australian Steel Institute
  • Related Links:
  • Code:
Thanks for your attention on this kind request.
BR
[*]This post has been made by CivilEA Post-Generator V2.3.1
[-] The following 1 user Likes malc's post:1 user Likes malc's post
  • hatkam
