Civil Engineering Association eBooks Geotechnical Engineering Foundation & Geotechnics in general Critical state soil mechanics via finite elements
 cace-01
User ID: 15651
Threads: 440
Likes: 10,522 in 867 posts
Given Likes: 7468
10-12-2011, 12:40 PM (This post was last modified: 10-12-2011, 12:50 PM by Dell_Brett.)
Author: Arul M. Britto, Michael John Gunn | Size: ~15 MB | Format: PDF | Publisher: John Wiely & Sons | Year: 1987 | pages: 244 | ISBN: 9780853129370
[Image: 43506531465548094208.jpg]
(image added by moderator)
Engineers have to predict the behaviour of various materials when they are loaded by mechanical forces. Geotechnical engineers are no different to other engineers in this respect : they have to predict the behaviour of soil whereas other engineers deal with steel, concrete, wood, plastics or fluids. In describing the behaviour of materials, engineers use a number of conceptual 'models' which are simplifications of real behaviour. Examples of these models include linear elastic solids, perfectly plastic solids and viscous fluids. If we compare the behaviour of each engineering material with the appropriate conceptual model, then we will always find some differences in detail. However, the important point is that the conceptual model is often sufficiently accurate for the purposes of engineering analysis and design. Associated with each of the examples listed above there is a collection of standard solutions to commonly occurring problems to which the engineer can refer (i.e. the theories of elasticity, plasticity and fluid mechanics) .
Soil behaviour conforms less to the models of material behaviour that we have mentioned so far than do most engineering materials. This is because soil is a two-phase material consisting of solid particles and wa ter. Its response to being loaded is inheren tly more complex than the response of steel or concrete, for example. Another complicating factor arises because the distribution of soil properties in a typical deposit (such as stiffness and strength) is non-uniform. In particular, soil properties always vary with the depth below the ground surface and this will usually have to be taken into account in engineering design.
Links from ebooksclub.org
[-] The following 21 users Like cace-01's post:21 users Like cace-01's post
  • Dell_Brett, 3fan, malc, isurya, sashka.od, Evandrojr, jcbv, dajabar, utan, tluc, serhioSPA, Grunf, cigutierrezg, mary, oanm2000, youceftli, slowet, lizard, Jackass, peymanlord, uetian19
08-25-2012, 10:03 AM
All links are dead.
kindly refresh...
  Soil Mechanics And Foundations, (Punmia & Jain, 2017) clerigo 1 3,829 02-26-2023, 06:27 AM
  Soil Mechanics and Foundation Engineering: Fundamentals and Applications 1st Edition poolmand 1 1,959 08-02-2021, 07:31 AM
Last Post: cace-01
  Theoretical Soil Mechanics By Karl Terzaghi babak 16 11,577 08-24-2020, 08:03 AM
  Soil Mechanics and Foundation Engineering - Raj Dobblo 3 2,617 04-12-2020, 02:51 PM
Last Post: ska51
  Craig's Soil Mechanics 6th, 7th 8th ed + Solutions Manual 7th ed robertsas 24 15,735 04-01-2020, 12:27 PM
Last Post: sabooryan
  Soil Mechanics Fundamentals amindoxiti 4 3,257 09-27-2019, 07:21 AM
  Advanced Soil Mechanics - by Braja M. Das babak 17 11,115 06-11-2019, 05:07 PM
Last Post: ska51
