Civil Engineering Association eBooks Codes, Manual & Handbook AWWA AWWA D103 Factory-Coated Bolted Steel Tanks for Water Stor
09-15-2011, 05:04 PM (This post was last modified: 01-15-2024, 12:43 PM by Administrator.)
ANSI/AWWA D103-09, AWWA Standard for Factory-Coated Bolted Steel Tanks for Water Storage
Author: AWWA | Size: 9.2 MB | Format: PDF | Publisher: ANSI/AWWA | Year: 2009 | pages: 145
[Image: 92897225572661511890.jpg]
The purpose of this standard is to provide minimum requirements for the design, construction, inspection, and testing of new cylindrical, factory coated, bolted carbon-steel tanks for the storage of water. This standard is only applicable to tanks with a base elevation substantially at ground level.
1.1.1 Tank roofs. All tanks storing potable water shall have roofs. Roofs may be column-supported, self-supported, or aluminum dome. Tanks storing nonpotable water may be constructed without roofs.
1.1.2 Items not described. This standard does not cover all details of design and construction. Details that are not addressed shall be designed and constructed to be as adequate and as safe as those that would otherwise be provided under this standard. This standard is not applicable to tanks of corrugated construction. This standard is not applicable to tanks constructed of stacked plates or sheets laminated to form multiple layers.
1.1.3 Local requirements. This standard is not intended to cover storage tanks erected in areas subject to regulations more stringent than the requirements contained within this standard. In such cases, this standard should be followed where it does not conflict with local requirements. Where more stringent local, municipal, county, or state government requirements apply, such requirements shall be specified and this standard shall be interpreted to supplement them.
Major revisions
This edition of the standard includes numerous corrections, updates, revisions, and new material to clarify some of the existing requirements. Sections were rearranged and revisions made to eliminate contractual language. Metric equations and dimensions were added.
Sec. 1 General was revised to clarify that corrugated tanks and tanks constructed of multiple layers of steel were not applicable to the standard.
Sec. 2 References was revised and updated.
Sec. 4 Materials was revised and includes additional grades of plates, sheets, structural shapes, hardware, and other tank construction materials.
Sec. 5 General Design was revised to include maximum thickness of flat-panel shell plates of 0.5 in. (12.7 mm), foundation anchor bolt Sec. 5.9.4 was revised, and reinforcing criteria for diameter of connections was decreased from 4 in. (102 mm) to 2 in. (51 mm). Bolted piping flanges Figure 2 was eliminated.
Sec. 7 Accessories for Tanks was revised regarding ladder requirements to bring into compliance with updated OSHA regulations 29 CFR Part 1910.
Sec. 8 Welding was revised and updated regarding qualifications, procedures, and inspection.
Sec. 14 Seismic Design and Sec. 15 Wind Design were revised extensively to reflect the requirements of the International Building Code and ASCE 7.
Appendix A Commentary for Factory-Coated Bolted Carbon-Steel Tanks for Water Storage is added to provide background information for many of the requirements contained in the standard.
Other general and specific revisions, additions, and corrections were made throughout the standard.
[-] The following 19 users Like ir_71's post:19 users Like ir_71's post
  • blaze, Dell_Brett, 3fan, jcbv, malc, hcardenas, kowheng, peixoto, Jackass, tluc, roaming79, duazo2009, ssobhan, lednar_ved, jacky899, ashcivilea, bubieng, bigone, limber_jmc
 limber_jmc
User ID: 15291
Threads: 0
Likes: 0 in 0 posts
Given Likes: 4
03-21-2015, 10:12 PM
Dear ir_71
Please reupload again AWWA D103-09.
Thanks!
 pedzaquino
User ID: 16816
Threads: 6
Likes: 36 in 12 posts
Given Likes: 2273
09-04-2019, 08:45 AM
pls renew link. or if theres a newer version of this manual. pls share.
thank you
  AWWA B304: Liquid Oxygen for Ozone Generation for Water, Wastewater, and Reclaimed W poolmand 0 2,815 01-16-2024, 08:10 AM
  AWWA B114: Reverse Osmosis and Nanofiltration Systems for Water Treatment poolmand 0 1,255 01-15-2024, 12:28 PM
  AWWA A100: Water Wells poolmand 0 1,491 01-15-2024, 11:44 AM
  AWWA C602: Cement-Mortar Lining of Water Pipelines in Place—4 In. (100 mm) and Larger poolmand 0 1,258 01-15-2024, 10:34 AM
  AWWA M42: Steel Water-Storage Tanks Dell_Brett 3 3,066 07-02-2016, 05:22 AM
Last Post: mnovo
