Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] A unified analysis model for energy dissipation devices used in seismic structures
[Request] A unified analysis model for energy dissipation devices used in seismic structures
 chitbk
User ID: 20116
Threads: 17
Likes: 2 in 2 posts
Given Likes: 69
08-04-2011, 11:09 AM
Hi
I need paper in science direct : "A unified analysis model for energy dissipation devices used in seismic structures"
"Semi-active control of a building complex with variable friction
dampers "
"Method of estimating the parameters of tunedmass dampers for seismic applications"
"Semi-active tuned mass dampers for seismic protection of civil
structures"
can you help me ,
Thanks
 terrorruban
User ID: 29563
Threads: 17
Likes: 98 in 24 posts
Given Likes: 925
08-04-2011, 12:55 PM (This post was last modified: 08-04-2011, 01:04 PM by terrorruban.)
here are two papers
other paper
fourth paper
.pdf   Method of estimating the parameters of tunedmass dampers for seismic applications.pdf (Size: 1.55 MB / Downloads: 51)
.pdf   SEMI-ACTIVE TUNED MASS DAMPERS FOR SEISMIC PROTECTION OF CIVIL STRUCTURES.pdf (Size: 446.15 KB / Downloads: 43)
.pdf   A Unified Analysis Model for Energy Dissipation Devices Used in Seismic Structures.pdf (Size: 965.03 KB / Downloads: 50)
.pdf   Semi-active control of a building complex with variable friction dampers.pdf (Size: 1.03 MB / Downloads: 41)
[-] The following 8 users Like terrorruban's post:8 users Like terrorruban's post
  • NBZ1400, llbb, chitbk, zrilek, blaze, ting tsai huang, marion33, tluc
  [REQUEST] Journal of Applied Mechanics;A Model for Vortex Induced Oscillation of Structures s0p9015 2 2,567 09-19-2016, 05:51 AM
Last Post: xnr09
  [REQUEST] A Model Code for the Displacement-Based Seismic Design of Structures Editors: G.M. Ca dynaquake 3 3,420 07-09-2014, 10:44 AM
Last Post: RyanRS
  [REQUEST] Energy Analysis of Cable-Stayed Bridges netsonicyxf 1 1,533 05-23-2014, 03:25 PM
Last Post: pezhmankhan
  [REQUEST] Environmental Wind Engineering and Design of Wind Energy Structures apocalipse 2 2,062 01-03-2014, 08:35 PM
Last Post: Dell_Brett
  [REQUEST] Seismic performance of cold formed steel structures, and risk analysis and management ssobhan 0 1,629 04-23-2013, 08:14 AM
Last Post: ssobhan
  [REQUEST] Static Pushover Analysis Based on an Energy-Equivalent SDOF System 3fan 2 2,170 04-01-2013, 03:54 PM
Last Post: asim99
  [REQUEST] Passive Energy Dissipation Systems for Structural Design and Retrofit david-smith 0 1,538 10-25-2012, 05:30 PM
Last Post: david-smith
