Civil Engineering Association eBooks Structural Dynamics and Earthquake Engineering Near-Fault Seismic Ground Motions
 amott
User ID: 346
Threads: 1
Likes: 8 in 2 posts
Given Likes: 0
08-01-2011, 07:42 PM
Author: Dreger, Douglas S., Hurtado, Gabriel, Chopra, Anil K., Larsen, Shawn C. | Size: 3.9 MB | Format: PDF
Bridges that cross faults are subject to static deformation that occurs at almost the same time as the arrival of dynamic pulse-like ground motions. Static offsets can be as large as several centimeters to many meters and strong ground motion velocity pulses exceeding 100 cm/s have been observed. Near-fault records, in the distance range of 10 to 100s of meters from faults are essentially nonexistent except for a few cases and therefore numerical simulation of ground motions for such near-fault situations is necessary. The paper presents simulated ground motions to 17.5 Hz, 15-100m from the fault for a Mw6.5 earthquake using an elastic finite-difference code. Simulations for homogeneous earth structure are compared for uniform and heterogeneous fault rupture scenarios. To investigate asymmetry of ground motions on opposite sides of a dipping reverse fault the dislocation method of Okada (1992) is used to compute static offset. From those results a simplified procedure for the simulation of near-fault time histories is developed. All of the simulations assume linear elasticity, and it is noted that the computed strain is as high as 10-4 - 10-3, and it is likely that there would be significant non-linear behavior in this near-fault region.
[-] The following 7 users Like amott's post:7 users Like amott's post
  • Grunf, mastermind, jacs127, melkat, kowheng, Dell_Brett, zrilek
08-01-2011, 08:32 PM
[Image: 44448513555988273268.jpg]
[Image: comments.png]
Uploaded: Aug/01/2011, File Size: 3.794 MB , PDF, Paginated, NOT-Bookmarked, Searchable text, 40 pages
[-] The following 23 users Like Grunf's post:23 users Like Grunf's post
  • malc, gatob, jacs127, melkat, ting tsai huang, kowheng, ISTRAKTURA, blaze, Jackass, Dell_Brett, tluc, attila, zrilek, seriousboy, nhim4mat2006, Clouseau, sasan7351, mmontazeri, ELAHI1979, ssobhan, draluka, Gkatzogias, subin91
 sinamaleki
User ID: 20260
Threads: 1
Likes: 154 in 14 posts
Given Likes: 28
11-23-2014, 06:27 AM
RE:Near-Fault Seismic Ground Motions
Direct Link
[-] The following 8 users Like sinamaleki's post:8 users Like sinamaleki's post
  • malc, ssobhan, Dell_Brett, oanm2000, bridgeengineer, Mohammad6299, Sumatra, PinkPant
  Spatial Variation of Seismic Ground Motions: Modeling and Engineering Applications Flexi 3 4,220 01-23-2017, 10:26 PM
  Seismic Ground Response Analysis cace-01 1 1,980 02-20-2015, 04:12 PM
Last Post: Veggeta
  Selecting and Scaling Earthquake Ground Motions for Performing Response-History Analy gulilero 0 1,680 11-08-2012, 01:04 AM
Last Post: gulilero
  Practices and Procedures for Site-Specific Evaluations of Earthquake Ground Motions mahyarov 0 1,449 10-25-2012, 07:45 PM
Last Post: mahyarov
  Probabilistic Seismic Demand Analysis for the Near-Fault Zone (PhD Thesis) Sumatra 0 1,631 12-27-2011, 04:32 PM
Last Post: Sumatra
  RECOMMENDED GUIDELINES FOR LIQUEFACTION EVALUATIONS USING GROUND MOTIONS FROM PROBA jacs127 0 1,641 07-13-2011, 04:29 AM
Last Post: jacs127
  Simulation of Synthetic Ground Motions for Specified Earthquake and Site Characterist pezhmankhan 1 2,285 03-22-2011, 09:08 AM
