Civil Engineering Association eBooks Structural Books Other Materials (Wood, Brick, etc.) BIA - Technical Notes & Briefs on Brick Construction
 gulilero
Italy
User ID: 14057
Threads: 113
Likes: 4,989 in 647 posts
Given Likes: 6732
08-01-2011, 04:44 PM
Author: BIA | Size: 22.5 MB | Format: PDF | Publisher: BIA | Year: 1960's to 2009 | pages: 88 Tech Notes & 8 Brick Briefs | ISBN: -
[Image: 82755411148221987414.jpg]
Brick Industry of Association (BIA)
Technical Notes are rewritten to include new technical information. The issue date of a current Technical Note is shown between brackets [ ].
Current editions supersede earlier editions.
The designation Reissued indicates that the edition of the Technical Note shown in brackets [ ] has been thoroughly reviewed and found to be technically accurate. Other editions dated on or after the bracketed [ ] date are still valid; only minor editorial changes have been made. The reissued date appears in parentheses ( ).
Missing numbers have been discontinued.
The list follows:
1 [June 2006] Cold and Hot Weather Construction
2 Rev [Jan./Feb. 1975] (Reissued March 1999) Glossary of Terms Relating to Brick Masonry
3 Rev [July 2002] Overview of Building CodeRequirements for Masonry Structures ACI 530-02/ASCE 5-02/TMS 402-02 and Specifications for Masonry Structures ACI 530.1-02/ASCE 6-02/TMS 602-02
3A [Dec. 1992] Brick Masonry Material Properties
3B [May 1993] Brick Masonry Section Properties
4 Rev [Jan. 1982] (Reissued Sept. 1997) Heat Transmission Coefficients of Brick Masonry Walls
4B Rev [Feb. 2002] Energy Code Compliance of Brick Masonry Walls
5A [June 1970] (Reissued Aug. 2000) Sound Insulation – Clay Masonry Walls
6 Rev [May 1972] (Reissued Dec. 1985) Painting Brick Masonry
6A [Aug. 2008] Colorless Coatings for Brick Masonry
7 [Dec. 2005] Water Penetration Resistance – Design and Detailing
7A [Dec. 2005] Water Penetration Resistance – Materials
7B [Dec. 2005] Water Penetration Resistance – Construction and Workmanship
8 [Jan. 2008] Mortars for Brickwork 8B [Oct. 2006] Mortars for Brickwork– Selection and Quality Assurance
9 [Dec. 2006] Manufacturing of Brick
9A [Oct. 2007] Specifications for and Classification of Brick
9B Rev [Dec. 2003] Manufacturing, Classification and Selection of Brick – Selection, Part III
10 [Feb. 2009] Dimensioning and Estimating Brick Masonry
11 Rev [Dec. 1971] (Reissued Aug. 2001) Guide Specifications for Brick Masonry, Part I
11A Rev [June 1978] (Reissued Sept. 1988) Guide Specifications for Brick Masonry, Part II
11B Rev [Feb. 1972] (Reissued Sept. 1988) Guide Specifications for Brick Masonry, Part III
11C Rev [July 1972] (Reissued May 1998)
Guide Specifications for Brick Masonry, Part IV
11D [Aug. 1972] (Reissued Sept. 1988) Guide Specifications for Brick Masonry, Part IV Continued
11E Rev [Sept. 1991] Guide Specifications for Brick Masonry, Part V, Mortar and Grout
13 [Dec. 2005] Ceramic Glazed Brick Exterior Walls
14 [Mar. 2007] Paving Systems Using Clay Pavers
14A [Oct. 2007] Paving Systems Using Clay Pavers on a Sand Setting Bed
14B [June 2010] Paving Systems Using Clay Pavers on a Bituminous Setting Bed
15 Rev [May 1988] Salvaged Brick
16 [Mar. 2008] Fire Resistance of Brick Masonry
17 Rev [Oct. 1996] Reinforced Brick Masonry, Introduction
17A Rev [Aug. 1997] Reinforced Brick Masonry – Materials and Construction
17B Rev [Mar. 1999] Reinforced Brick Masonry Beams
17L Rev [Feb./Mar. 1973] (Reissued Sept.1988) Four-inch RBM Curtain and Panel Walls
17M [July 1968] (Reissued Sept. 1988) Reinforced Brick Masonry Girders – Examples
18 [Oct. 2006] Volume Changes – Analysis and Effects of Movement
18A [Nov. 2006] Accommodating Expansion of Brickwork
19 Rev [Jan. 1993] Residential Fireplace Design
19A Rev [May 1980] (Reissued Aug. 2000) Residential Fireplaces, Details and Construction
19B Rev [June 1980] (Reissued Apr. 1998) Residential Chimneys – Design and Construction
19C Rev [Oct. 2001] Contemporary Brick Masonry Fireplaces
19D [Jan. 1983] (Reissued June 1987) Brick Masonry Fireplaces, Part I, Russian-Style Heaters
19E [1983] (Reissued Feb. 1998) Brick Masonry Fireplaces, Part II Fountain and Contemporary Style Heaters
20 [June 2006] Cleaning Brickwork
21 Rev [Aug. 1998] Brick Masonry Cavity Walls – Introduction
21A Rev [Feb. 1999] Brick Masonry Cavity Walls – Selection of Materials
21B [Apr. 2002] Brick Masonry Cavity Walls – Detailing
21C Rev [Oct. 1989] Brick Masonry Cavity Walls – Construction
23 [June 2006] Stains – Identification and Prevention
23A [June 2006] Efflorescence – Causes and Prevention
24 Rev [June 2002] Brick Masonry Bearing Walls – Introduction
24C Rev [Sept./Oct. 1970] (Reissued May 1988) The Contemporary Bearing Wall– Introduction to Shear Wall Design
24F Rev [Nov./Dec. 1974] (Reissued Sept.1988) The Contemporary Bearing Wall– Construction
24G [Dec. 1968] (Reissued Feb. 1987) The Contemporary Bearing Wall – Detailing
26 Rev [Sept. 1994] Single Wythe Bearing Walls
27 Rev [Aug. 1994] Brick Masonry Rain Screen Walls
28 Rev [Aug. 2002] Anchored Brick Veneer, Wood Frame Construction
28A [Apr. 2008] Adding Brick Veneer to Existing Construction
28B [Dec. 2005] Brick Veneer / Steel Stud Walls
28C [Jan. 1986] (Reissued Jan. 2001) Thin Brick Veneer – Introduction
29 Rev [July 1994] Brick in Landscape Architecture – Pedestrian Applications
29A Rev [Nov. 1968] (Reissued Jan. 1999) Brick in Landscape Architecture – Garden Walls
29B [Apr. 1967] (Reissued May 1988) Brick in Landscape Architecture – Miscellaneous Applications
30 Rev [Mar. 1999] Bonds and Patterns in Brickwork
31 Rev [Jan. 1995] Brick Masonry Arches
31A [Oct. 1967] (Reissued July 1986) Structural Design of Brick Masonry Arches
31B Rev [Nov./Dec. 1981] (Reissued May 1987) Structural Steel Lintels
31C Rev [Feb. 1971] (Reissued Aug. 1986) Structural Design of Semicircular Brick Masonry Arches
36 Rev [July/Aug. 1981] (Reissued Jan. 1998) Brick Masonry Details, Sills and Soffit
36A Rev [Sept./Oct. 1981] (Reissued Feb. 2001) Brick Masonry Details, Caps and Copings, Corbels and Racking
39 Rev [Nov. 2001] Testing for Engineered Brick Masonry – Brick and Mortar
39A [July/Aug. 1975] (Reissued Dec. 1987) Testing for Engineered Brick Masonry – Determination of Allowable Design Stresses
39B Rev [Mar. 1988] Testing for Engineered Brick Masonry – Quality Control
40 Rev [Aug. 2001] Prefabricated Brick Masonry – Introduction
41 [Jan. 2008] Hollow Brick Masonry
42 Rev [Nov. 1991] Empirical Design of Brick Masonry
43 Rev [May/June 1981] Passive Solar Heating with Brick Masonry – Part I Introduction
43C [Mar. 1980] (Reissued Feb. 2001) Passive Solar Cooling with Brick Masonry, Part I –Introduction
43D [Sept./Oct. 1980] (Reissued Sept. 1988) Brick Passive Solar Heating Systems, Part IV– Material Properties
43G [Mar./Apr. 1981] (Reissued Sept. 1986) Brick Passive Solar Heating Systems, Part VII – Details and Construction
44 [Apr. 1986] Anchor Bolts for Brick Masonry
44A [May 1986] (Reissued Aug. 1997) Fasteners for Brick Masonry
44B Rev [May 2003] Wall Ties for Brick Masonry
45 [Feb. 1991] (Reissued July 2001) Brick Masonry Noise Barrier Walls – Introduction
45A [Apr. 1992] Brick Masonry Noise Barrier Walls – Structural Design
46 [Dec. 2005] Maintenance of Brick Masonry
47 [June 2006] Condensation – Prevention and Control
48 [June 2009] Sustainability and Brick
Mirror:
DIRECT LINKS thumbup
[Image: comments.png]
A lot of good advise for those detailing & designing brick
[-] The following 13 users Like gulilero's post:13 users Like gulilero's post
  • cesar3226, blaze, sasan7351, medo_sk, malc, kowheng, zrilek, Jackass, Dell_Brett, knrsa, monter, Hengki, uetian19
  Reinforced Grouted Brick Masonry arshiakh 0 1,568 02-24-2013, 02:17 PM
Last Post: arshiakh
