Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] Secondary Moments of Continuous Prestressed Concrete
[Request] Secondary Moments of Continuous Prestressed Concrete
 quatermain
User ID: 21366
Threads: 64
Likes: 23 in 19 posts
Given Likes: 113
08-01-2011, 12:37 PM
Secondary Moments of Continuous Prestressed Concrete Beams Using Closed Form Equation
ASCE Conf. Proc. doi:10.1061/41031(341)22
Venketaramani Tiruchirapalli1 and Riyadh Hindi, Ph.D., P.Eng.2
ISBN:
978-0-7844-1031-8
Abstract:
This paper provides practical engineers with an equation to calculate the secondary moments of prestressed concrete continuous beams. Normally the prestressed secondary moments are calculated by deriving it from the net moment and the primary moments. This involves extensive calculations and sometimes complex integration techniques but the proposed equation described in this paper will give the secondary moment directly. The secondary moment calculated using the equation is compared with the secondary moment calculated using various existing methods such as support displacement method, moment distribution method and stiffness method, and also using the structural analysis software STAAD. For the purpose of analysis, two span, three span and four span beams are considered. This equation can be applied to multiple span beams/girders. Finally the equation is used to show the principle of concordant profile where the secondary moments are zero at the intermediate supports.
Thank you all.
 melkat
User ID: 1901
Threads: 74
Likes: 3,565 in 324 posts
Given Likes: 1623
08-02-2011, 01:16 AM
Hi Quatermain,
"Secondary Moments of Continuous Prestressed Concrete Beams Using Closed Form Equation"
[-] The following 13 users Like melkat's post:13 users Like melkat's post
  • aslam, simanta, kowheng, bhawk0, jf28, malc, blaze, quatermain, Jackass, Dell_Brett, tluc, ykhackhack, viet2010
  [REQUEST] Design and Typical Details of Connections for Precast and Prestressed Concrete mulham lee 2 4,296 01-02-2022, 06:43 AM
Last Post: pezhmankhan
  [REQUEST] Design of Prestressed Concrete to Eurocode 2, Second Edition camto2 2 3,546 12-05-2019, 04:48 AM
  [REQUEST] Seismic Design of Precast/Prestressed Concrete Structures aslam 1 2,537 06-06-2019, 03:45 PM
Last Post: temp1366
  [REQUEST] Design of Prestressed Concrete to AS3600-2009, 2nd Ed by Gilbert, Mickleborou & Ranzi rohailiyaz 2 2,138 02-23-2016, 01:51 PM
Last Post: rohailiyaz
  Designing for earthquake using precast/prestressed concrete by Ned Cleland,S.K.Ghosh aslam 2 2,695 12-14-2014, 06:30 PM
Last Post: gulilero
  Reinforced and Prestressed Concrete Design to EC2 mantas1985 1 2,877 10-29-2014, 04:24 PM
Last Post: Immelmann
  [REQUEST] Precast Prestressed Concrete Bridge Design Manual Third Edition peixoto 1 2,659 05-11-2014, 06:03 PM
Last Post: arshiakh
