Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS EN 10249:1996 Cold formed sheet piling of non alloy steels
05-13-2011, 12:33 PM (This post was last modified: 05-13-2011, 12:39 PM by ir_71.)
BS EN 10249-1:1996 Cold formed sheet piling of non alloy steels. Technical delivery conditions
Size: 0.17 MB | Format: PDF | Publisher: CEN | Year: 1995 | pages: 11
[Image: 16968908811462292461.jpg]
This part of this European Standard specifies the requirements for cold formed non alloy steel sheet piling produced from hot rolled strip or sheet with a thickness equal to or greater than 2mm in respect of its chemical composition, mechanical and technological properties and delivery conditions. The products specified are for general, structural and civil engineering works. Requirements concerning the tolerances on shape and dimensions are specified in Part 2 of this European Standard.
BS EN 10249-2:1995 Cold formed sheet piling of non alloy steels - Part 2: Tolerances on shape and dimensions
Size: 0.17 MB | Format: PDF | Publisher: CEN | Year: 1995 | pages: 8
[Image: 09002301858167461628.jpg]
This part of this European Standard specifies the tolerances on dimensions, squareness of ends, straightness and mass of cold formed non alloy steel sheet piles which are defined in EN 10249-1.
  • peixoto, kowheng, Jackass, toa011, sivlad, techno
  BS EN 10219:2006 Cold formed welded structural hollow sections of non-alloy and fine ir_71 4 4,226 06-03-2019, 09:56 AM
Last Post: concreteok
  BS 5427-1:1996 Code of practice for the use of profiled sheet for roof and wall cladd mybest 3 3,173 01-11-2014, 12:27 PM
  BS EN 10248:1996 Hot rolled sheet piling of non alloy steels ir_71 1 2,192 02-19-2013, 12:45 PM
  UK_NA to BS EN 1996 melkat 0 1,446 10-06-2012, 04:38 PM
Last Post: melkat
  BS 12:1996 Specification for Portland cement ir_71 1 1,995 12-24-2011, 06:18 PM
Last Post: kvtasp
