Civil Engineering Association eBooks Codes, Manual & Handbook AISC AISC 303: Code of Standard Practice for Steel Buildings and Bridges
03-10-2011, 11:57 AM (This post was last modified: 01-12-2022, 11:19 AM by Administrator.)
AISC 303-10 Code of Standard Practice for Steel Buildings and Bridges
Size: 1.57 MB | Format: PDF | Publisher: AISC | Year: 2010 | pages: 84
[Image: 58472801928050301951.jpg]
Scope
This Code sets forth criteria for the trade practices involved in steel buildings, bridges, and other structures, where other structures are defined as those structures designed, fabricated, and erected in a manner similar to buildings, with building-like vertical and lateral load resisting elements. In the absence of specific instructions to the contrary in the contract documents, the trade practices that are defined in this Code shall govern the fabrication and erection of structural steel.
Commentary:
The practices defined in this Code are the commonly accepted standards of custom and usage for structural steel fabrication and erection, which generally represent the most efficient approach. This Code is not intended to define a professional standard of care for the owners designated representative for design, change the duties and responsibilities of the owner, contractor, architect or structural engineer of record from those set forth in the contract documents, or assign to the owner, architect or structural engineer of record any duty or authority to undertake responsibility inconsistent with the provisions of the contract documents. This Code is not applicable to steel joists or metal building systems, which are addressed by SJI and MBMA, respectively.
[-] The following 26 users Like ir_71's post:26 users Like ir_71's post
  • kowheng, Grunf, blaze, Dell_Brett, rezart, we_mbm, henrycv, vardan, seriousboy, toa011, tamboon, cordoba123, jcoronellr, orambo, zainseiya, pezhmankhan, goober, carolinandra, monter, hmwere, fer962933, Jackass, portal61, bigone, oanm2000, ykhackhack
 arshiakh
User ID: 37777
Threads: 100
Likes: 3,224 in 617 posts
Given Likes: 214
03-01-2013, 04:52 PM
All links are dead.
Download this book from following link:
[-] The following 9 users Like arshiakh's post:9 users Like arshiakh's post
  • jcbv, sodapas, malc, eng donny, slowet, oanm2000, ykhackhack, bigone, sacem
 Rapaig
User ID: 20672
Threads: 7
Likes: 119 in 16 posts
Given Likes: 160
04-23-2013, 02:25 PM
[-] The following 6 users Like Rapaig's post:6 users Like Rapaig's post
  • blaze, PinkPant, ykhackhack, Dell_Brett, bigone, Arm1n
 ssobhan
User ID: 1054
Threads: 335
Likes: 8,975 in 1,182 posts
Given Likes: 2465
04-23-2013, 02:42 PM
direct link;
[-] The following 13 users Like ssobhan's post:13 users Like ssobhan's post
  • subin91, ykhackhack, Rapaig, ruaumoko, bigone, hignacio43, ali akbar, chairatpk, Munykong, malc, usman, pram, zainseiya
 bigone
User ID: 4505
Threads: 92
Likes: 5,722 in 517 posts
Given Likes: 7145
04-01-2016, 06:09 PM (This post was last modified: 01-12-2022, 11:17 AM by Administrator.)
AISC 303-16 Code of Standard Practice for Steel Buildings and Bridges
Draft
Author(s)/Editor(s): AISC | Size: 1.36 MB | Format: PDF | Quality: Original preprint | Publisher: AISC | Year: 2016 | pages: 90 | ISBN: Standards Under Public Review
[Image: 69981511961518990889.jpg]
Steel Buildings and Bridges (AISC 303-16)
[-] The following 17 users Like bigone's post:17 users Like bigone's post
  • jcbv, Dell_Brett, tomtumx, milova, miquan, simanta, hatkam, blaze, PinkPant, oanm2000, bridgeengineer, temp1366, cace-01, Jackass, sodapas, anfaga, slowet
 ESTRUCTO
User ID: 2666
Threads: 0
Likes: 183 in 21 posts
Given Likes: 35
11-10-2016, 04:46 PM
Author(s)/Editor(s): AISC | Size: 3545 KB | Format: PDF | Quality: Unspecified | Publisher: AISC | Year: 2016 | pages: 84
[Image: 34927171537925518995.jpg]
AISC 303-16 "Code of Standard Practice for Steel Buildings and Bridges"
As in any industry, trade practices have developed among those that are involved in the design, purchase, fabrication and erection of structural steel. This Code provides a useful framework for a common understanding of the acceptable standards when contracting for structural steel. As such, it is useful for owners, architects, engineers, general contractors, construction managers, fabricators, steel detailers, erectors and others associated with con-struction in structural steel. Unless specific provisions to the contrary are contained in the contract documents, the existing trade practices contained herein are considered to be the standard custom and usage of the industry and are thereby incorporated into the relation-ships between the parties to a contract.
It is important to note the differences in design requirements between buildings and bridges. ANSI/AISC 360 and 341 establish the design requirements for buildings and building-like structures, and this Code sets complementary commercial and technical requirements. For highway bridges, the governing design requirements are established by AASHTO and implemented by the contracting agency; the commercial provisions of the Code are appli-cable, but technical provisions, such as tolerances, are not addressed.
This Code is written—and intended to be utilized in practice—as a unified document. Contract documents may supercede individual provisions of the Code as provided in Section 1.1, except when doing so would violate a requirement of the applicable building code.
[-] The following 13 users Like ESTRUCTO's post:13 users Like ESTRUCTO's post
  • struc_engg, zrilek, oanm2000, pezhmankhan, Jackass, jcbv, Dell_Brett, PinkPant, ruaumoko, araza023, milova, bigone, cace-01
 AtoZmail
United States
User ID: 91376
Threads: 2
Likes: 78 in 5 posts
Given Likes: 0
04-27-2017, 02:04 PM
UPDATED DIRECT LINK FROM SOURCE
[-] The following 21 users Like AtoZmail's post:21 users Like AtoZmail's post
  • amindoxiti, Nita1391, zrilek, PinkPant, rami1976, Aviator, Dell_Brett, milova, subin91, malc, agelos100, monter, oanm2000, blackjack, promo8, bigone, febo927, er.shyams, Sumatra, kristoffer_89, spat
02-07-2023, 11:56 AM
AISC 303-22 Code of Standard Practice for Steel Buildings and Bridges
| Size: 1.15 MB| Format: PDF| Quality: Original preprint| Year: 2022
[Image: 79812979352547343974.png]
[-] The following 17 users Like poolmand's post:17 users Like poolmand's post
  • babakfeyzi, cheosmith, Dell_Brett, cace-01, subin91, rendel_©, rami1976, milova, zrilek, lisine, Aviator, PinkPant, civilfafa, kowheng, melekeen, Umer.Aleem, alcalan57
  AISC - Steel Construction Manual dinu69in 24 24,997 01-02-2026, 09:31 PM
Last Post: pezhmankhan
  ANSI/AISC N690: Specification for Safety-Related Steel Structures for Nuclear Facil ir_71 5 12,407 08-18-2025, 07:07 AM
  AISC 207: Standard for Certification Programs poolmand 1 8,499 08-18-2025, 07:02 AM
  AISC - Steel Design Guides Administrator 74 80,746 08-18-2025, 06:17 AM
  AISC Model Review and Approval for Structural Steel poolmand 0 3,412 04-29-2024, 07:29 AM
  AISC BIM & VDC FOR STRUCTURAL STEEL poolmand 0 2,974 04-29-2024, 07:27 AM
  AISC Conference: Composite Construction in Steel and Concrete VIII poolmand 0 2,804 12-04-2023, 09:17 AM
