Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS EN 1708-1:2010 Welding — Basic welded joint details in steel Part 1: Pressurized c
02-23-2011, 10:12 AM
BS EN 1708-1:2010 Welding — Basic welded joint details in steel Part 1: Pressurized components
Author: CEN/TC 121 | Size: 1.64 MB | Format: PDF | Publisher: CEN | Year: 2010 | pages: 76
[Image: 13968067412710568326.jpg]
The purpose of this European Standard is to exemplify commonly accepted welded connections in pressure systems. It does not promote the standardization of connections that may be regarded as mandatory or restrict development in any way. Stress analysis rules should be considered if necessary.
This standard contains examples of connections welded by:
 Manual metal-arc welding with covered electrode (111);
 Submerged arc welding (12);
 Gas shielded metal arc welding (13);
 Tungsten inert gas arc welding; TIG-welding (14);
 Plasma arc welding (15) processes (process numbers according to EN ISO 4063) in steel pressure systems. Other processes by agreement.
This standard covers welded joint details in steel, but can be applied to other metallic materials. In such cases the shape and dimensions of the weld should be checked. The estimation of the suitability of welded connections for special service conditions, for example corrosion and fatigue are not specially considered.
  • Grunf, kowheng, dizz, oanm2000, andtangh, seriousboy, cordoba123, zrilek, monter, Clouseau, sivlad, warbeast, peixoto
 andersen3
User ID: 464
Threads: 54
Likes: 6,117 in 996 posts
Given Likes: 1243
02-19-2013, 02:20 PM
all links dead; reposted here:
password
[-] The following 8 users Like andersen3's post:8 users Like andersen3's post
  • vvvv, blaze, ssobhan, Jackass, warbeast, knrsa, peixoto, Dell_Brett
  BS EN 14015:2004 Welded Steel Tanks for the Storage of Liquids malc 3 2,859 02-26-2015, 05:04 PM
Last Post: Veggeta
  EN 14188-1:2004 Joint fillers and sealants - Part 1: Specifications for hot applied s ir_71 2 2,444 01-18-2015, 09:07 AM
Last Post: Mohammad6299
  BS 4515-1:2009 Specification for welding of steel pipelines on land and offshore mybest 2 3,041 07-17-2014, 02:11 AM
Last Post: legend2611
  BS EN ISO 5817:2007 Welding. Fusion-welded joints in steel, nickel, titanium and thei mybest 1 3,127 02-21-2013, 01:54 PM
Last Post: arshiakh
  PD 8010-3:2009 Code of practice for pipelines – Part 3: Steel pipelines on land – Gui ir_71 0 1,787 10-07-2012, 05:15 AM
  PD 8010-1:2004 Code of practice for pipelines — Part 1: Steel pipelines on land ir_71 1 2,680 10-07-2012, 05:01 AM
  BS EN 10305 part 1 to part 6- Steel tubes for precision applications mybest 0 1,867 11-28-2011, 06:48 AM
Last Post: mybest
