Civil Engineering Association eBooks Codes, Manual & Handbook EN EN 15037 Precast Concrete Products. Beam-and-block floor systems
12-14-2010, 04:02 AM
Author: CEN/TC 229 | Size: 4 MB | Format: PDF | Publisher: CEN | Year: 2008-2009 | pages: 250
[Image: 64335269018039396181.jpg]
EN 15037-1:2008
Precast concrete products - Beam-and-block floor systems - Part 1: Beams
This European Standard deals with the requirements, the basic performance criteria and evaluation of conformity for precast beams made of reinforced or prestressed normal or lightweight concrete according to EN 1992-1-1:2004, with or without clay shell, used in conjunction with blocks in compliance with prEN 15037-2 or prEN 15037-3 or prEN 15037-4 or prEN 15037-5, with or without cast in-situ concrete for the construction of beam-and-block floor and roof systems. Examples of typology of floor and roof systems are given in Annex B.
It is essential that the total depth of the beam be comprised between 60 mm and 300 mm and the beams be at centres of not more than 1,00 m.
For higher depth, it is essential that the precast concrete beams be in compliance with EN 13225.
The products covered by this standard are intended to be used as structural floor and roof systems, including parking areas for light vehicles corresponding to traffic category F of EN 1991-1-1:2002, which are not subjected to fatigue loading.
The products may be used in seismic areas provided they fulfil the requirements specific to this use.
EN 15037-2:2009
Precast concrete products - Beam-and-block floor systems - Part 2: Concrete blocks
This European Standard deals with the requirements and the basic performance criteria for blocks made in normal or lightweight aggregate concrete, used in conjunction with precast concrete beams in compliance with EN 15037-1, with or without cast-in-situ concrete for the construction of beam-and-block floor and roof systems.
Examples of typology of floor and roof systems are given in Annex B of EN 15037-1:2007.
EN 15037-3:2009
Precast concrete products - Beam-and-block floor systems - Part 3: Clay blocks
This European Standard deals with the requirements and the basic performance criteria for blocks made in clay, used in conjunction with precast concrete beams in compliance with EN 15037-1, with or without cast-in-situ concrete for the construction of beam-and-block floor and roof systems.
Examples of typology of floor and roof systems are given in Annex B of EN 15037-1:2008.
  • kowheng, usman, mulham lee, Grunf, zrilek, roaming79, Administrator , blaze
  EN 13369:2004 (Common rules for precast concrete products) raffah 2 3,335 03-07-2018, 01:53 PM
  EN 12843:2004 Precast concrete products - Masts and poles ir_71 3 3,567 01-24-2015, 01:19 AM
Last Post: concreteok
  EN 14992:2007 Precast concrete products - Wall elements ir_71 1 2,670 01-20-2014, 03:27 PM
Last Post: milova
  EN 12794:2005 Precast concrete products - Foundation piles ir_71 1 2,615 04-11-2013, 01:59 AM
Last Post: st77bel
  EN 14843:2007 Precast concrete products - Stairs ir_71 2 2,982 10-29-2010, 04:55 PM
  EN 15015:2007 Precast concrete products - Bridge elements ir_71 0 2,040 10-24-2010, 05:21 AM
