Civil Engineering Association eBooks Structural Books Concrete Simplified Computations for Effective Moment of Inertia Ie and Minimum Thickness to A
 ivanveliki
User ID: 1250
Threads: 47
Likes: 886 in 110 posts
Given Likes: 480
11-19-2010, 10:30 PM (This post was last modified: 11-19-2010, 11:10 PM by usman.)
Simplified Computations for Effective Moment of Inertia Ie and Minimum Thickness to Avoid Deflection Computations
Author: Jacob S. Grossman | Size: 1.51 MB | Format: PDF | Year: 1981 |
Publisher: ACI JOURNAL, Proceedings V. 78, No. 6, Nov.-Dec. 1981, pp. 423-439.
[Image: 22426729171361023494.jpg]
An approximate simplified procedure is described for estimating the effective moment of inertia I, for beams, T-beams, or one-way slabs constructed of normal weight aggregate concrete or lightweight concrete, and reinforced with 40-80 ksi reinforcing bars. The results are compatible with Ie values obtained from Eq. (9-7) of ACI 318-77. The simplified equations do not require computations for moment of inertia of the cracked section Icr, nor the reinforcing requirements initially. Also described is a simplified procedure for establishing minimum member depth so that deflection computations to ascertain serviceability may be avoided when designing the majority of one-way members
[-] The following 22 users Like ivanveliki's post:22 users Like ivanveliki's post
  • usman, shanta, strengr, melkat, jcoronellr, kowheng, robertsas, chigozie, blaze, rezart, malc, cappotchi, Galileo, Dell_Brett, ssi3k, Grunf, oanm2000, mgdario, OSHO, salahcivil, Nilupa, techno
  Recommended LRFD Minimum Flexural Reinforcement RequirementsRecommended LRFD Minimum mahyarov 0 1,420 10-25-2012, 02:52 PM
Last Post: mahyarov
