Civil Engineering Association eBooks Codes, Manual & Handbook SEAOC: Seismic Design Manual - vol 1, 2, 3
 robertsas
Indonesia
User ID: 655
Threads: 159
Likes: 5,665 in 416 posts
Given Likes: 3149
03-23-2009, 11:02 AM (This post was last modified: 03-17-2011, 06:12 PM by usman.)
Seismic Design Manual (SEAOC)
Vol 1 : Code Application Examples
[Image: 84931018532653409025.jpg]
The various code application examples of Volume I are organized in numerical order by 1997 UBC section number. To find an example for a particular provision of the code, look at the upper, outer corner of each page, or in the table of contents.
Volume I of the SEAOC Seismic Design Manual: Code Application Examples deals with interpretation and use of the seismic provisions of the 1997 Uniform Building Code (UBC). The Seismic Design Manual is intended to help the reader understand and correctly use the UBC seismic provisions and to provide clear, concise, and graphic guidance on the application of specific provisions of the code. It primaril addresses the major seismic provisions of Chapter 16 of the UBC, with interpretation of specific provisions and examples highlighting their proper application. Volume I presents 55 examples that illustrate the application of specific seismic provisions of the UBC. Each example is a separate problem, or group of problems, and deals primarily with a single code provision. Each example begins with a description of the problem to be solved and a statement of given information. The problem is solved through the normal sequence of steps, each of which are illustrated in full. Appropriate code references for each step are identified in the right-hand margin of the page.
[-] The following 37 users Like robertsas's post:37 users Like robertsas's post
  • essam2109, essam2109, emmi, emmi, ruaumoko, preceptor, henrycv, hans01, civilteam, pezhmankhan, YeiYei, jayborre, shaqee, rendel_©, julioreptil, pm81, Dell_Brett, Clouseau, rezart, narendra, ikoleci, tamboon, knrsa, Quantumm, mafiyaboss, sodapas, zainseiya, blaze, lednar_ved, ibg0203, ykhackhack, ting tsai huang, khayagski, bigone, igor1234, TurboXUser, K.Lee
 robertsas
Indonesia
User ID: 655
Threads: 159
Given Likes: 3149
03-23-2009, 11:09 AM (This post was last modified: 03-17-2011, 06:09 PM by usman.)
Vol2 : Building Design Examples
[Image: 88592631511159411144.jpg]
This document is the second volume of the three-volume SEAOC Seismic Design Manual. The first volume, “Code Application Examples,” was published in April 1999. These documents have been developed by the Structural Engineers Association of California (SEAOC) with funding provided by SEAOC. Their purpose is to provide guidance on the interpretation and use of the seismic requirements in the 1997 Uniform Building Code (UBC), published by the International Conference of Building Officials (ICBO), and SEAOC’s 1999 Recommended Lateral Force Requirements and Commentary (also called the Blue Book).
Volume II contains six examples. These illustrate the seismic design of the following structures: (1) a two-story wood light frame residence, (2) a three-story wood light frame building, (3) a three-story cold formed light frame building, (4) a one-story masonry building with panelized wood roof, (5) a one-story tilt-up building with panelized wood roof, and (6) the design of a tilt-up wall panel with large openings.
[-] The following 36 users Like robertsas's post:36 users Like robertsas's post
  • essam2109, essam2109, babak, babak, preceptor, maad59, henrycv, civilteam, wa_sin_29, pezhmankhan, YeiYei, shaqee, rendel_©, julioreptil, abouferass88, pm81, civilgr, Dell_Brett, Clouseau, rezart, avanchai, ikoleci, cve_jule, tamboon, knrsa, Quantumm, mafiyaboss, sodapas, zainseiya, lednar_ved, ibg0203, ykhackhack, ting tsai huang, khayagski, bigone, K.Lee
 robertsas
Indonesia
User ID: 655
Threads: 159
Given Likes: 3149
03-23-2009, 11:12 AM (This post was last modified: 03-17-2011, 06:09 PM by usman.)
Vol 3 : Building Design Examples
[Image: 30448329180310247602.jpg]
This document is the third volume of the three-volume SEAOC Seismic Design Manual. The first volume, Code Application Examples, was published in April 1999. The second volume, Building Design Examples: Light Frame, Masonry and Tilt-up was published in April 2000. These documents have been developed by the Structural Engineers
Volume III contains ten examples. These illustrate the seismic design of the following structures:
1. Three steel braced frames (special, ordinary, and chevron)
2. Eccentric braced frame
3. Two steel moment-resisting frames (special and ordinary)
4. Concrete shear wall
5. Concrete shear wall with coupling beams
6. Concrete special moment-resisting frame
7. Precast concrete cladding
[-] The following 39 users Like robertsas's post:39 users Like robertsas's post
  • essam2109, essam2109, emmi, emmi, Nedian, Nedian, rohailiyaz, rohailiyaz, ruaumoko, henrycv, civilteam, pezhmankhan, jcoronellr, shaqee, rendel_©, Yasir, pm81, Dell_Brett, rezart, ikoleci, avanchai, cve_jule, yantonegr, tamboon, knrsa, deadlord, Quantumm, mafiyaboss, sodapas, zainseiya, YeiYei, lednar_ved, ibg0203, ykhackhack, ting tsai huang, khayagski, bigone, Rapaig, K.Lee
03-17-2011, 08:40 AM (This post was last modified: 12-15-2012, 04:36 AM by kowheng.)
Mirror Links Vol 1 : Code Application Examples :
Bookmark PDF|RAR 1.66|0.83 MB
[-] The following 31 users Like kowheng's post:31 users Like kowheng's post
  • melkat, seriousboy, malc, Dell_Brett, Clouseau, vardan, rezart, yantonegr, DamaD, usman, Quantumm, sodapas, zainseiya, Sumatra, robertsas, YeiYei, GMianG, blaze, ibmarin, pedzaquino, zrilek, Jackass, eliseo.as, oscargon, paitaconst, slowet, vvvv, ykhackhack, Gkatzogias, bigone, harsono
03-17-2011, 08:50 AM (This post was last modified: 12-15-2012, 04:40 AM by kowheng.)
Mirror Links Vol2 : Building Design Examples :
Bookmark PDF|RAR 3.65|3.32 MB
[-] The following 32 users Like kowheng's post:32 users Like kowheng's post
  • Grunf, seriousboy, malc, Dell_Brett, Clouseau, vardan, rezart, cve_jule, yantonegr, DamaD, usman, Quantumm, sodapas, zainseiya, Sumatra, robertsas, YeiYei, anantparghi, blaze, ibmarin, pedzaquino, zrilek, Jackass, eliseo.as, oscargon, paitaconst, slowet, vvvv, ykhackhack, Gkatzogias, bigone, red_pool61
03-17-2011, 08:55 AM (This post was last modified: 12-15-2012, 04:44 AM by kowheng.)
Mirror Links Vol 3 : Building Design Examples:
Bookmark PDF|RAR 2.96|2.55 MB
[-] The following 34 users Like kowheng's post:34 users Like kowheng's post
  • momo2010, Grunf, seriousboy, robertsas, malc, Dell_Brett, techno, vardan, rezart, ArissB, cve_jule, yantonegr, DamaD, deadlord, usman, Quantumm, sodapas, zainseiya, zrilek, Sumatra, skyscraper, nickycruz, blaze, ibmarin, eliseo.as, oscargon, slowet, vvvv, TAFATNEB, ykhackhack, Gkatzogias, bigone, chicosi, harsono
07-05-2012, 11:45 AM
Seismic Design Manual - Volume III
[-] The following 9 users Like shadabg's post:9 users Like shadabg's post
  • pedzaquino, zrilek, Jackass, paitaconst, odiclas, slowet, Dell_Brett, ykhackhack, bigone
 david-smith
United States
User ID: 43924
Threads: 247
Likes: 4,023 in 582 posts
Given Likes: 1085
10-12-2012, 06:42 AM
Please if anyone have the newest version share to us.
SEAOC Updates and Errata:
[-] The following 3 users Like david-smith's post:3 users Like david-smith's post
  • ykhackhack, fbx_rdnk, bigone
 gulilero
Italy
User ID: 14057
Threads: 113
Likes: 4,989 in 647 posts
Given Likes: 6732
10-12-2012, 01:35 PM
SEAOC: Seismic Design Manuals
Vols. 1, 2, 3 in one winrar file
[-] The following 22 users Like gulilero's post:22 users Like gulilero's post
  • oanm2000, TAFATNEB, rezart, ykhackhack, blaze, dinu69in, Dell_Brett, carolinandra, malee, cace-01, eliseo.as, melekeen, lesgiu, bigone, malc, Petrit, simanta, nickycruz, emmi, TurboXUser, harsono, bridgeengineer
 bigone
User ID: 4505
Threads: 92
Likes: 5,722 in 517 posts
Given Likes: 7145
01-15-2014, 10:05 AM
SEAOC Seismic Design Manual Vol. 01, Code Application Examples_1999.pdf (7.7 MB)
SEAOC Seismic Design Manual Vol. 02, Building Design Examples Light Frame, Masonry and Tilt Up_2000.pdf (3.5 MB)
SEAOC Seismic Design Manual Vol. 03, Building Design Examples Steel, Concrete and Cladding_2000.pdf (2.8 MB)
[-] The following 5 users Like bigone's post:5 users Like bigone's post
  • blaze, Mohammad6299, eng donny, hatkam, spiderthan
Pages (2): 1 2 Next »
  SEAOC Blue Book: Seismic Design Recommendations 2009 Ernest0 1 2,275 03-31-2019, 08:14 PM
Last Post: sabooryan
  2006 IBC Structural/Seismic Design Manual kristoffer_89 6 8,198 04-10-2014, 03:21 AM
Last Post: malee
  Seismic Design Manual CFE 2008 Mexico leithowsky 3 5,152 05-20-2010, 05:14 PM
Last Post: leithowsky
