Civil Engineering Association Software Software Product Autodesk Products AutoRebar for Autodesk AutoCAD
Likes: 8,213 in 1,338 posts
09-18-2024, 04:53 AM (This post was last modified: 09-18-2024, 04:55 AM by poolmand.)
AutoRebar v2.1 & v3.2.2 x64 for Autodesk AutoCAD
[Image: selBBS.gif]
[Image: Crosstie.gif][Image: Spireb.gif]
AutoRebar provides Autodesk AutoCAD (and all vertical products) with an extra toolbar with specific objects for rebar detailing of reinforced concrete structures.
With AutoRebar you can now quickly produce high quality drawings by automating the repetitive tasks previously involved in rebar detailing with plain AutoCAD. You can now focus on the conceptual part of the design rather than having to deal with time-consuming CAD editing work.
There are four types of dynamic objects: Rebars, Marks, Call-outs and the Bar Bending Schedule.
Rebar objects can be created and stretched like polylines and the bar size quickly edited with a double click. Since all AutoRebar entities are graphically connected, a modification to one or more Rebars causes all the linked objects to update automatically.
The user can add a new Mark by selecting the Rebar to be linked, and double click it to edit data such as the bar grouping criteria, the bar spacing and the size of the range; alternatively, normal AutoCAD® dimensions can be linked to the Mark and used to specify the range of a bundle of bars in the concrete structure; AutoRebar calculates the total number of bars in that range. The great thing is, whenever you modify the concrete shape and stretch the dimension, the total number of bars updates on the fly.
The Bar Bending Schedule can be either inserted in the drawing or exported to Excel with a simple click, while the EXPLODESEL and EXPLODEALL commands explode the AutoRebar objects into standard AutoCAD entities. This can be useful to deliver your drawing to other users who want to open and edit your drawing without having to install AutoRebar on their computers.
[Image: homepage.png]
[Image: comments.png]
  • babakfeyzi, zrilek, Dell_Brett, oanm2000, mecheil.edwar, yehiaabdelkarim
08-18-2025, 09:58 AM (This post was last modified: 08-18-2025, 09:59 AM by poolmand.)
AutoRebar 2026 v3.3.2
[Image: Stirrup.gif]
[Image: selBBS.gif]
AutoRebar 2026 update:
AutoCAD 2026 compatibility.
Minor bug fixes.
Features carried over from AutoRebar 2025:
A redesigned user interface that seamlessly blends with AutoCAD.
All new internal engine for Rebars.
New Stirrup object.
New Loop object (circular stirrup).
New Spiral object.
New Crosstie command.
New Crosshairs objects along linear, circular and arc patterns.
Rebar and Crosshairs objects feature an optional offset-to-cover property for faster creation and editing.
Object snaps options for reinforcement objects: snap to centreline, snap to thickness, or snap to both centreline and thickness.
New spacing pattern property for Crosshairs.
Additional Crosshairs options, including automatic hatch fill.
Customizable default layer names and colors for AutoRebar objects and sub-objects.
Fully customizable format for Mark objects.
Tag property for Mark numbers (prefix).
New command for automatic renumbering of Marks to eliminate number gaps.
Marks can now be linked to Crosshairs to receive spacing/quantity data.
Bar Bending Schedules (BBS) format can be fully customized.
New command for BBS by selection.
New Bar List export command by selection.
Enabled Batch plot capability (note: requires the “Publish in background” option to be off).
New dictionary tool: users can specify symbols, terms, and sentences for AutoRebar to use in each component of the application. The new feature allows complete control on the technical terminology adopted by the software and produce drawings in any language.
Compatible with:
Autodesk AutoCAD
Version: 2026, 2025 , 2024 , 2023 , 2022 , 2021 , 2020 , 2019 , 2018 , 2017 , 2016 , 2015
Autodesk® Civil 3D®
Autodesk AutoCAD Electrical
Autodesk AutoCAD Mechanical
Autodesk AutoCAD Architecture
Autodesk AutoCAD MEP
Autodesk AutoCAD Map 3D
Autodesk AutoCAD Plant 3D
  • zrilek, Dell_Brett, rami1976
  Autodesk AutoCAD Civil 3D 2025 poolmand 2 5,455 12-02-2024, 01:09 PM
  Autodesk AutoCAD Plant 3D 2022 (x64) Pre-Cracked BennyP 1 10,170 10-27-2023, 04:10 PM
Last Post: Dalvisahi014
  Autodesk AutoCAD 2022 (x64) BennyP 5 13,266 03-29-2022, 11:33 AM
Last Post: Arigato
  Autodesk AutoCAD Civil 3D 2022 poolmand 2 11,194 03-13-2022, 03:04 PM
Last Post: pilitro
  Autodesk AutoCAD Raster Design 2019 BennyP 5 10,381 09-22-2021, 09:07 AM
  Autodesk Autocad 2016 (x64 + x32) Trial BennyP 3 11,222 05-22-2021, 05:55 AM
Last Post: kirankumarklk
  Autodesk Autocad Civil 3D 2021 babakfeyzi 8 12,924 05-19-2021, 08:59 AM
Last Post: Vatsalbu89
