Civil Engineering Association eBooks Codes, Manual & Handbook ACI ACI RAP-1: Structural Crack Repair by Epoxy Injection
Likes: 8,200 in 1,338 posts
08-28-2024, 06:30 AM
Author(s)/Editor(s): ACI Committee E706| Format: PDF| Quality: Original preprint
[Image: 43134726519931055817.png]
Field Guide to Concrete Repair Application Procedures
Certain things in life are inevitable. Some are said to include death, taxes, and concrete cracks! The latter is subject to volumes of literature on causes and cures. Some of the more typical causes for concrete cracking include:
- Drying shrinkage;
- Thermal contraction or expansion;
- Settlement;
- Lack of appropriate control joints;
- Overload conditions that produce flexural, tensile, or shear cracks in concrete;
- Restraint of movement;
One of the potentially effective repair procedures is to inject epoxy under pressure into the cracks. The injection procedure will vary, subject to the application and location of the crack(s), with horizontal, vertical, and overhead cracks requiring somewhat different approaches. The approach used must also consider accessibility to the cracked surface and the size of the crack.
[-] The following 1 user Likes poolmand's post:1 user Likes poolmand's post
  • babakfeyzi
  ACI 351.5: Epoxy Grout Installation between Foundations and Equipment Bases—Specifica poolmand 1 1,514 12-06-2025, 11:46 AM
  [CivilEA Exclusive] ACI SPEC-548.14: Repairing Concrete with Epoxy Mortar poolmand 0 496 12-06-2025, 11:17 AM
  ACI 548.11: Application of Epoxy and Latex Adhesives for Bonding Freshly Mixed and Ha poolmand 0 1,175 12-14-2024, 01:16 PM
  ACI RAP-2: Crack Repair by Gravity Feed with Resin poolmand 0 1,266 08-28-2024, 06:32 AM
  [CivilEA Exclusive] ACI 548.16: Epoxy and Aggregate High Friction Surface on Concrete—Specification poolmand 0 1,441 11-06-2023, 10:44 AM
  [CivilEA Exclusive] ACI 548.8: Construction Specification for Type EM (Epoxy Multi-Layer) Polymer poolmand 0 1,471 11-06-2023, 10:37 AM
  ACI 548.13: Multi-Component Epoxy Adhesive for Bonding to Concrete poolmand 0 1,185 05-02-2023, 12:11 PM
