Civil Engineering Association eBooks Codes, Manual & Handbook ACI ACI SP-236: Deformation Capacity and Shear Strength of Reinforced Concrete Members
Likes: 8,200 in 1,338 posts
03-04-2024, 08:32 AM (This post was last modified: 03-04-2024, 10:43 AM by Administrator.)
ACI SP-236: Deformation Capacity and Shear Strength of Reinforced Concrete Members Under Cyclic Loading
| Size: 22.1 MB| Format: PDF| Quality: Original preprint| Year: 2006 | ISBN: 9780870312090
[Image: 05812576463133595130.jpg]
Earthquakes worldwide have clearly demonstrated the vulnerability of reinforced concrete members to degradation in shear strength when subjected to cyclic loading. Such degradation can lead to significant damage to the structure and, possibly, even collapse. With the advancement of performance-based earthquake engineering, where the response of the structure must be traced through all levels of damage, there is a significant need to accurately define the deformation capacity and shear strength for such members. This symposium publication represents an effort from researchers across the globe trying to address this challenging problem.
Although at the time of publication there are some methodologies that can be used in performance-based earthquake engineering, there is a significant need for improved methods better suited for these types of applications. Furthermore, one of the concerns often expressed by researchers is that test data used in the past to develop and calibrate existing models consisted of relatively small data sets. This problem is compounded by differences between experimental studies in aspects such as the type of load history used, the manner in which deformations were recorded during tests, and the definition of displacement and strength at failure.
The recent development of the PEER column database, hosted by the University of Washington, provided a valuable resource to overcome some of these problems. It presented researchers with a larger pool of data, which included the full hysteretic response of every column in the data set. Although this represented a very significant step forward, efforts of this kind should continue to improve the ability of researchers to calibrate and evaluate models for shear strength and deformation capacity.
A joint technical session was organized by Joint ACI-ASCE Committees 441, Reinforced Concrete Columns, and 445, Shear and Torsion, during the American Concrete Institute’s Fall 2004 Convention in San Francisco, CA. The goal of the technical session was to showcase recent developments in this area, with the hope that continued discussion will lead to improved models that are suitable for performance-based engineering.
This symposium publication is a collection of technical articles presented at that meeting and represents an effort from Joint ACI-ASCE Committees 441 and 445 to continue the technical discussion on this topic
  • babakfeyzi, subin91, jcbv, PinkPant, Dell_Brett
  ACI E702.5: Designing Concrete Structures: Slender Reinforced Concrete Wall Design - poolmand 0 1,337 08-28-2024, 05:32 AM
  ACI SP-344: Examples for the Design of Reinforced and Prestressed Concrete Members Un poolmand 0 1,589 03-04-2024, 08:35 AM
  ACI SP-353: Design of Slabs for Serviceability and Punching Shear Strength poolmand 0 1,516 03-04-2024, 07:24 AM
  [CivilEA Exclusive] ACI 440.10: Fire Resistance of FRP-Strengthened Concrete Members - TechNote poolmand 0 1,480 11-06-2023, 05:44 AM
  [CivilEA Exclusive] ACI 364.2: Increasing Shear Capacity within Existing Reinforced Concrete Structures poolmand 0 1,433 11-05-2023, 06:37 AM
  ACI 224.2: Cracking of Concrete Members in Direct Tension ivanveliki 1 2,826 05-09-2023, 09:48 AM
  ACI 349.2: Guide to the Concrete Capacity Design (CCD) Method robertsas 4 5,263 05-08-2023, 10:16 AM
