Civil Engineering Association eBooks Codes, Manual & Handbook ISO BS ISO 16172 Steel sheet, metallic-coated by the continuous hot-dip process for corru
Likes: 8,200 in 1,338 posts
01-28-2024, 01:01 PM
BS ISO 16172:2018 Steel sheet, metallic-coated by the continuous hot-dip process for corrugated steel pipe
| Size: 4.19 MB| Format: PDF| Quality: Scanner| Year: 2018-11| pages: 9
[Image: 22844659848148693886.jpg]
This document is applicable to the minimum requirements for steel sheet used in the manufacture of corrugated steel pipe, in coils, flat cut lengths and corrugated cut lengths metallic-coated by the continuous hot-dip process.
This product is intended for storm sewers, culverts, drains and similar uses.
Several metallic-coated materials are covered, which relies on users to determine which product best serves their needs. Four different metallic coatings are included:
— zinc coated;
— zinc-5 % aluminium-mischmetal alloy coated;
— 55 % aluminium-zinc alloy coated;
— aluminium-silicon alloy coated.
  • jcbv, babakfeyzi, PinkPant, kowheng
