Civil Engineering Association eBooks Codes, Manual & Handbook ACI ACI 549.4: Guide to Design and Construction of Externally Bonded Fabric-Reinforced Ce
Likes: 8,213 in 1,338 posts
01-23-2024, 12:10 PM
ACI 549.4R-20: Guide to Design and Construction of Externally Bonded Fabric-Reinforced Cementitious Matrix and Steel-Reinforced Grout Systems for Repair and Strengthening of Concrete Structures
| Size: 41.2 MB| Format: PDF| Quality: Scanner| Year: 2020| pages: 40 | ISBN: 9781641950985
[Image: 99633907645269270265.jpg]
Fabric-reinforced cementitious matrix (FRCM) and steel-reinforced grout (SRG) systems for rehabilitation and strengthening concrete structures is an alternative to traditional techniques such as fiber-reinforced polymers (FRPs), steel plate bonding, section enlargement, and external post-tensioning. An FRCM/SRG is a composite material consisting of one or more layers of inorganic matrix reinforced with dry fibers in the form of open mesh or fabric. The inorganic matrixes are typically cement-based, lime-based, or geopolymer. When adhered to concrete structural members, they form an FRCM/SRG system that acts as supplemental, externally bonded reinforcement. This guide addresses the history and use of FRCM and SRG systems rehabilitation and strengthening, their unique material properties, and recommendations on their design, construction, and inspection. Guidelines are based on experimental research, analytical work, and field applications.
  • PinkPant, babakfeyzi, tomtumx, subin91, sodapas, kowheng
  ACI 440.2: Guide for the Design and Construction of Externally Bonded FRP Systems ir_71 5 5,158 01-17-2024, 07:34 AM
  ACI 526: Guide for Design and Construction with Autoclaved Aerated Concrete Panels poolmand 0 1,697 01-17-2024, 07:27 AM
  ACI 343.1 Guide for the Analysis and Design of Reinforced and Prestressed Concrete Gu poolmand 0 1,764 11-26-2023, 11:51 AM
  ACI 440.7: Guide for Design & Construction of Externally Bonded FRP Systems for Stren ir_71 1 2,768 11-06-2023, 05:40 AM
  ACI 549.6: Guide to Design and Construction of Externally Bonded Fabric-Reinforce poolmand 1 1,738 05-09-2023, 12:39 PM
  ACI 440.1: Guide for the Design and Construction of Structural Concrete Reinforced wi poolmand 0 1,621 05-08-2023, 01:39 PM
  ACI 421.3: Guide to Design of Reinforced Two-Way Slab Systems poolmand 0 1,516 05-08-2023, 01:32 PM
