Civil Engineering Association eBooks Codes, Manual & Handbook AWWA AWWA B301: Liquid Chlorine
01-16-2024, 08:02 AM
AWWA B301-18 Liquid Chlorine
| Size: 4.9 MB| Format: PDF| Quality: Scanner| Year: 2018 | ISBN: 9781625762825
[Image: 22918064285460209231.jpg]
This standard describes liquid chlorine for use in potable water, wastewater, and reclaimed water treatment.
The purpose of this standard is to provide the minimum requirements for liquid chlorine, including physical, chemical, sampling, testing, packaging, and shipping requirements.
This standard can be referenced in documents for purchasing and receiving liquid chlorine and can be used as a guide for testing the physical and chemical properties of liquid chlorine samples. The stipulations of this standard apply when this document has been referenced and then only to liquid chlorine used in the treatment of potable water, wastewater, or reclaimed water.
  • babakfeyzi, PinkPant
  AWWA B408 LIQUID POLYALUMINUM CHLORIDE poolmand 0 2,836 01-20-2024, 11:56 AM
  AWWA B407 LIQUID FERRIC CHLORIDE poolmand 0 2,734 01-20-2024, 11:54 AM
  AWWA B404 LIQUID SODIUM SILICATE poolmand 0 2,664 01-20-2024, 11:46 AM
  AWWA B403 ALUMINUM SULFATE — LIQUID, GROUND, OR LUMP poolmand 0 2,710 01-20-2024, 11:44 AM
  AWWA B306: Aqua Ammonia (Liquid Ammonium Hydroxide) poolmand 0 2,640 01-16-2024, 08:15 AM
  AWWA B304: Liquid Oxygen for Ozone Generation for Water, Wastewater, and Reclaimed W poolmand 0 2,815 01-16-2024, 08:10 AM
