Civil Engineering Association eBooks Codes, Manual & Handbook AWWA AWWA B112: Microfiltration and Ultrafiltration Membrane Systems
01-15-2024, 12:22 PM
AWWA B112-19 Microfiltration and Ultrafiltration Membrane Systems
| Size: 9 MB| Format: PDF| Quality: Scanner| Year: 2019 | ISBN: 9781625763419
[Image: 22069026541186602270.jpg]
The purpose of this standard is to provide a minimum set of requirements for MF and UF systems used for water and reclaimed water filtration systems. This standard is intended to assist with the design, procurement, installation, and commissioning of MF and UF systems.
This standard sets minimum requirements for microfiltration (MF) and ultrafiltration (UF) membrane systems for water and reclaimed water filtration systems. This standard does not cover the membranes used in biological wastewater treatment, such as membrane bioreactors.
This standard can be referenced for design, procurement, installation, and commissioning of MF and UF systems used for water and reclaimed water filtration systems.
  • PinkPant, babakfeyzi
  AWWA B130: Membrane Bioreactor Systems poolmand 0 1,230 01-15-2024, 12:33 PM
  AWWA B116: Electrodialysis and Ion-Exchange Membrane Systems poolmand 0 1,325 01-15-2024, 12:30 PM
  AWWA B114: Reverse Osmosis and Nanofiltration Systems for Water Treatment poolmand 0 1,261 01-15-2024, 12:28 PM
