Civil Engineering Association eBooks Codes, Manual & Handbook AWWA AWWA A100: Water Wells
01-15-2024, 11:44 AM
AWWA A100-20: Water Wells
| Size: 21.02 MB| Format: PDF| Quality: Scanner| Year: 2020 | ISBN: 9781647170059
[Image: 37924538542651635971.jpg]
This standard describes the minimum requirements for vertical water supply wells and is designed primarily for municipal and industrial applications.
The purpose of this standard is to provide the minimum requirements for water wells, including consideration of the influences of geologic and hydrologic conditions and water quality and well construction. This standard can be referenced in specifications for constructing water wells and can be used as a guide for vertical water supply wells. The stipulations of this standard apply when this document has been referenced and only to water wells used in water supply service applications. Application of this standard is not limited by well depth.
  • ska51, PinkPant, babakfeyzi
  AWWA B304: Liquid Oxygen for Ozone Generation for Water, Wastewater, and Reclaimed W poolmand 0 2,813 01-16-2024, 08:10 AM
  AWWA B114: Reverse Osmosis and Nanofiltration Systems for Water Treatment poolmand 0 1,255 01-15-2024, 12:28 PM
  AWWA C602: Cement-Mortar Lining of Water Pipelines in Place—4 In. (100 mm) and Larger poolmand 0 1,256 01-15-2024, 10:34 AM
  AWWA D103 Factory-Coated Bolted Steel Tanks for Water Stor ir_71 2 4,169 09-04-2019, 08:45 AM
Last Post: pedzaquino
  AWWA M42: Steel Water-Storage Tanks Dell_Brett 3 3,064 07-02-2016, 05:22 AM
Last Post: mnovo
