Civil Engineering Association eBooks Codes, Manual & Handbook ASTM ASTM D5977: Standard Specification for High Load Rotational Spherical Bearings for B
01-15-2024, 10:22 AM
ASTM D5977-23 Standard Specification for High Load Rotational Spherical Bearings for Bridges and Structures
| Size: 2.76 MB| Format: PDF| Quality: Scanner| Year: 2023| pages: 5
[Image: 57521935121340324514.jpg]
This specification covers bridge bearings that consist of a spherical rotational element, where a stainless steel convex surface slides against a concave carbon steel plate covered with woven or sheet polytetrafluoroethylene (PTFE). The function of the bearing is to transfer loads and to accommodate any relative movement, including rotation between a bridge superstructure and its supporting structure, or both. The requirements of spherical bearings with a standard horizontal load (a maximum of 10 % of vertical) are discussed. The bearings are furnished in three types: fixed spherical bearing which is for rotation only, unidirectional sliding spherical bearing which is for rotation plus movement in one direction, and multi-directional sliding spherical bearing which is for rotation plus movement in all directions. The materials to be used in producing the bearings include: steel, stainless steel (flat sliding surface and convex surface), woven fabric polytetrafluoroethylene, and sheet polytetrafluoroethylene. The following different test methods shall be performed: proof load and rotation tests for fixed and expansion bearings, coefficient of friction test for expansion bearings only, PTFE (woven or sheet) bond test for expansion bearings only, and physical property test of both PTFEs for fixed and expansion bearings.
  • PinkPant, babakfeyzi
  ASTM D5265: Standard Test Method for Bridge Impact Testing poolmand 0 3,132 01-15-2024, 10:17 AM
  ASTM D4014: Standard Specification for Plain and Steel-Laminated Elastomeric Bearing poolmand 0 2,912 01-15-2024, 10:13 AM
  ASTM C1518: Standard Specification for Precured Elastomeric Silicone Joint Sealants poolmand 0 2,972 01-15-2024, 10:06 AM
  ASTM D516: Standard Test Method for Sulfate Ion in Water poolmand 0 3,170 11-12-2023, 08:07 AM
  [CivilEA Exclusive] ASTM D4829-21: Standard Test Method for Expansion Index of Soils poolmand 0 3,230 11-01-2023, 07:18 AM
  ASTM D2573/D2573M: Standard Test Method for Field Vane Shear Test in Saturated Fine-G poolmand 0 2,806 10-28-2023, 06:32 AM
  [CivilEA Exclusive] ASTM D4186M: Standard Test Method for One-Dimensional Consolidation Properties of Sat poolmand 0 2,794 10-24-2023, 11:10 AM
