Civil Engineering Association eBooks Codes, Manual & Handbook ASTM ASTM D516: Standard Test Method for Sulfate Ion in Water
11-12-2023, 08:07 AM
ASTM D516-22: Standard Test Method for Sulfate Ion in Water
| Size: 1.9 MB| Format: PDF| Year: 2022| pages: 6
Significance and Use
5.1 The determination of sulfate is important because it has been reported that when this ion is present in excess of about 250 mg/L in drinking water, it causes a cathartic action (especially in children) in the presence of sodium and magnesium, and gives a bad taste to the water.
5.2 Test Method D4327 (“Test Method of Anions in Water by Suppressed Ion Chromatography”) may be used.
Scope
1.1 This turbidimetric test method covers the determination of sulfate in water in the range from 5 mg/L to 40 mg/L of sulfate ion (SO4−−).
1.2 This test method was used successfully with drinking, ground, and surface waters. It is the user's responsibility to ensure the validity of this test method for waters of untested matrices.
1.3 Former gravimetric and volumetric test methods have been discontinued. Refer to Appendix X1 for historical information.
1.4 The values stated in SI units are to be regarded as standard. No other units of measurement are included in this standard.
1.5 This standard does not purport to address all of the safety concerns, if any, associated with its use. It is the responsibility of the user of this standard to establish appropriate safety, health, and environmental practices and determine the applicability of regulatory limitations prior to use.
1.6 This international standard was developed in accordance with internationally recognized principles on standardization established in the Decision on Principles for the Development of International Standards, Guides and Recommendations issued by the World Trade Organization Technical Barriers to Trade (TBT) Committee.
  • PinkPant, utan, subin91, kowheng
  ASTM D5977: Standard Specification for High Load Rotational Spherical Bearings for B poolmand 0 2,789 01-15-2024, 10:22 AM
  ASTM D5265: Standard Test Method for Bridge Impact Testing poolmand 0 3,132 01-15-2024, 10:17 AM
  ASTM D4014: Standard Specification for Plain and Steel-Laminated Elastomeric Bearing poolmand 0 2,912 01-15-2024, 10:13 AM
  ASTM C1518: Standard Specification for Precured Elastomeric Silicone Joint Sealants poolmand 0 2,972 01-15-2024, 10:06 AM
  STM D6927: Standard Test Method for Marshall Stability and Flow of Asphalt Mixtures poolmand 0 2,780 11-04-2023, 10:57 AM
  [CivilEA Exclusive] ASTM D4829-21: Standard Test Method for Expansion Index of Soils poolmand 0 3,230 11-01-2023, 07:18 AM
  ASTM D2573/D2573M: Standard Test Method for Field Vane Shear Test in Saturated Fine-G poolmand 0 2,806 10-28-2023, 06:32 AM
