Civil Engineering Association eBooks Codes, Manual & Handbook ACI [CivilEA Exclusive] ACI 364.4: Determining the Load Capacity of a Structure when Structural Drawings are
Likes: 8,200 in 1,338 posts
11-05-2023, 06:40 AM (This post was last modified: 01-08-2024, 08:53 AM by Administrator.)
ACI PRC-364.4-21: Determining the Load Capacity of a Structure when Structural Drawings are Unavailable
Author(s)/Editor(s): ACI Committee 364| Format: PDF| Year: 2021| pages: 4
[Image: 69035521281983815064.jpg]
When a structural evaluation to determine capacity is to be performed, knowledge of member sizes, reinforcing details, and material properties is required. In cases where this information is not readily available through drawing document records, it needs to be obtained through in-place measurements and sampling.
bearing capacity; gravity loads; investigation program; lateral loads; load capacity; load testing; material property assessment; structural configuration; visual inspection.
[-] The following 7 users Like poolmand's post:7 users Like poolmand's post
  • PinkPant, babakfeyzi, kowheng, albani, jcbv, blaze, milova
 concreteok
E-Book Moderator
Malaysia
User ID: 4764
Threads: 50
Likes: 4,962 in 637 posts
Given Likes: 3500
11-09-2023, 05:47 AM
point to correct file
concrete solution advocate
[-] The following 6 users Like concreteok's post:6 users Like concreteok's post
  • odiclas, jcbv, Dell_Brett, PinkPant, civilfafa, subin91
