Civil Engineering Association eBooks Codes, Manual & Handbook ACI [CivilEA Exclusive] ACI-TMS 122.1: Thermal Bridge Mitigation for Buildings Having Concrete and Masonry
Likes: 8,200 in 1,338 posts
10-21-2023, 11:59 AM (This post was last modified: 10-21-2023, 12:08 PM by poolmand.)
ACI-TMS CODE-122.1-21: Thermal Bridge Mitigation for Buildings Having Concrete and Masonry Walls and Masonry Veneer—Code Requirements and Commentary(SI and IN-LB units)
Author(s)/Editor(s): Joint ACI-TMS Committee 122 | Size: 23.26 MB| Format: PDF| Quality: Scanner| Year: 2022| pages: 20
[Image: 58542612388558892309.jpg]
[Image: 04842970355704707090.jpg]
This code prescribes minimum design and construction requirements for mitigating thermal bridges in the building envelopes of new buildings and additions to existing buildings. It applies to buildings having concrete or masonry walls; masonry veneer, including veneer attached to frame walls; and balconies or components that extend through the building envelope. It also has criteria for metal thermal bridges in these buildings.
This code is applicable to commercial and mid- to high-rise residential buildings that use either electricity or fossil fuel (regardless of the generation source). It can be used with applicable energy codes and standards.
thermal bridge.
  • zrilek, PinkPant, Dell_Brett, babakfeyzi, subin91, kowheng
  [CivilEA Exclusive] ACI-TMS 122.3: Thermal Properties of Concrete and Masonry for Use in Determining Ener poolmand 0 2,354 12-15-2024, 06:51 AM
  ACI TMS 122.2: Thermal Properties of Concrete and Masonry for Use poolmand 0 1,414 05-26-2024, 04:51 AM
  ACI 216.1: Fire Resistance of Concrete & Masonry Construction Assemblies nibbi 2 2,443 05-08-2023, 08:44 AM
  ACI 207.2: Report on Thermal and Volume Change Effects on Cracking of Mass Concrete portal61 2 3,393 05-03-2023, 05:26 AM
