Civil Engineering Association Software Software Product Bentley Products Bentle RAM Connection v23
Likes: 8,175 in 1,337 posts
10-04-2023, 07:39 AM (This post was last modified: 04-22-2024, 01:16 PM by Administrator.)
Bentle RAM Connection Standalone v23.00.00.190 x64
Bentley RAM Connection offers the best flexibility for the design of different shear, moment, braces, splices and base plates connection types. Perform analysis and design of virtually any connection type and verify your connections in seconds, all with comprehensive calculations, including seismic compliance. Increase your productivity with optimized workflows and full integration of 3D design models, including the ability to customize the application with your preferences. Efficiently design and optimize a myriad of connections included in the AISC (ASD and LRFD), EC3, IS, GB, and BS specifications. Quickly complete all your connections, such as shear and moment connections, braced frame connections, column/beam splices, and base plates.
Capabilities:
- Comply with seismic requirements
Design and detail seismic force-resisting systems, generating seismic loads according to the relevant building code. Consider these forces in the design of elements and, where applicable, the design of frames and the larger structural system. Enforce the ductility requirements of the selected design code in element proportioning and detailing.
- Design structural steel connections
Design and detail structural steel connections, including beam-to-beam, beam-to-column, brace end, and complex multi-member connections. Simplify the arrangement of plates, stiffeners, bolts, and welds with a comprehensive library of standard connection types. Easily compare the economy and practicality of connection scenarios.
- Design to international standards
Extend the reach of your business practice and take advantage of global design opportunities by using a wide range of international standards and specifications in our design products. Complete your designs with confidence thanks to extensive support of international standards.
- Produce structural design documentation
Generate structural design documents including necessary plans and elevations that are used to convey the design intent. Changes made to the 3D model are automatically updated in the documentation.
- Produce structural details
Produce detailed 2D drawings directly from design results established in the structural model. Customize the style and format of the drawings using settings offered within the software.
  • Dell_Brett, PinkPant, zego2000, mowafi3m
 hzaheer
Member
User ID: 413
Threads: 16
Likes: 15 in 8 posts
Given Likes: 190
04-01-2025, 05:56 PM
all links dead
04-15-2025, 05:15 AM
[-] The following 1 user Likes poolmand's post:1 user Likes poolmand's post
  • rami1976
