Civil Engineering Association eBooks Codes, Manual & Handbook AWS AWS D14.6/D14.6M: Specification for Welding of Rotating Elements of Equipment
09-09-2023, 12:47 PM
AWS D14.6/D14.6M-2012: Specification for Welding of Rotating Elements of Equipment
| Size: 29.8 MB| Format: PDF| Quality: Scanner| Year: 4th Edition, 2012| pages: 88
[Image: 61850485715911277622.jpg]
This specification establishes minimum acceptable requirements for weld joint detail and fabrication by welding of rotating elements in new equipment. This specification also applies to the modification or repair by welding of rotating elements in existing equipment. Equipment types covered by this specification include, but are not limited to: crushers, fans, impellers, centrifugal impellers, kilns, pulpers, gears, sheaves, drive trains, crankshafts, flywheels, power transmission shafts, air moving devices, blowers, and rotating elements of hydro electric generating equipment. The intent of this specification is not to include steam or combustion turbine rotors, blading, or camshafts. This specification also applies to such products and procedures that are agreed to by the Manufacturer, Fabricator, or Repair Organization and the Owner.
Requirements contained herein are not intended to nullify or void the requirements of any law or governmental agency regulation or other codes applied to components. Additional requirements may be invoked by contract documents. The specification establishes the minimum acceptable practice at the time of its publication. It is not intended to restrict new developments or in any way to inhibit advances in the art and science of welding.
This specification is intended to promote the following:
(1) High quality construction and repair of welded rotating elements of equipment;
(2) Adequate initial and sustained performance of welded rotating elements of equipment;
(3) Personnel safety;
(4) Clear, concise fabrication practices that will be readily understood by the Manufacturer, Fabricator, or Repair Organization, Fabricator, Owner, and user; and
(5) Conservation of human and material resources in the fabrication of welded rotating elements of equipment.
This specification makes use of both U.S. Customary Units and the International System of Units (SI). These measurements may not be exact equivalents; therefore each system must be used independently of the other without combining in any way. The specification with the designation D14.6 uses U.S. Customary Units. The specification D14.6M uses SI Units. The latter are shown in appropriate columns in tables or within brackets ([ ]) when used in the text.
Safety and health issues and concerns are beyond the scope of this standard, and therefore are not fully addressed herein. Safety and health information is available from other sources, including, but not limited to ANSI Z49.1, Safety in Welding, Cutting, and Allied Processes, and applicable federal and state regulations.
  • babakfeyzi, PinkPant, kowheng
  [CivilEA Exclusive] A5.22 / A5.22M: SPECIFICATION FOR STAINLESS STEEL FLUX CORED AND METAL CORED WELDING poolmand 0 2,575 02-03-2025, 06:02 AM
  AWS D17.1/D17.1M: SPECIFICATION FOR FUSION WELDING FOR AEROSPACE APPLICATIONS poolmand 1 3,227 09-24-2024, 07:29 AM
  [CivilEA Exclusive] AWS D14.0/D14.0M: MACHINERY AND EQUIPMENT WELDING SPECIFICATION poolmand 0 2,824 09-24-2024, 07:18 AM
  AWS A5.14/A5.14M: Specification for Nickel and Nickel- Alloy Bare Welding Electrodes poolmand 1 3,109 01-27-2024, 11:18 AM
  AWS J1.3/J1.3M: SPECIFICATION FOR MATERIALS USED IN RESISTANCE WELDING ELECTRODES poolmand 0 2,781 01-22-2024, 12:10 PM
  AWS J1.1M/J1.1: SPECIFICATION FOR RESISTANCE WELDING CONTROLS poolmand 0 2,838 01-22-2024, 12:05 PM
  AWS G1.2M/G1.2: SPECIFICATION FOR STANDARDIZED ULTRASONIC WELDING TEST SPECIMEN FOR T poolmand 0 1,844 01-22-2024, 11:29 AM
