Civil Engineering Association eBooks Codes, Manual & Handbook AWS AWS D10.8: Recommended Practices for Welding of Chromium-Molybdenum Steel Piping and
Likes: 8,200 in 1,338 posts
09-04-2023, 11:40 AM
AWS D10.8-1996: Recommended Practices for Welding of Chromium-Molybdenum Steel Piping and Tubing
| Size: 8.26 MB| Format: PDF| Quality: Scanner| Year: 1996 Edition, 1996| pages: 19
[Image: 94243715454118463241.jpg]
These recommended practices apply to the arc welding of the following base-metal combinations:
(1) Similar chromium-molybdenum steels
(2) Dissimilar chromium-molybdenum steels
(3) Chromium-molybdenum to austenitic chromium-nickel stainless steels
(4) Chromium-molybdenum to either carbon or carbon-molybdenum steels
In this document, the chromium-molybdenum steel alloys are referred to as Cr-Mo steels.
Cr-Mo steels are used extensively in the power, chemical, and petroleum industries. The properties of such piping and tubing materials and the applicable fabrication and inspection requirements are addressed in a wide range of documents, including:
(1) ASTM Material Specifications
(2) ASME Codes for Pressure Piping, B31
(a) Power Piping (ANSI/ASME B31.1)
(b) Chemical Plant and Petroleum Refinery Piping (ANSI/ASME B31.3)
(3) ASME Boiler and Pressure Vessel Codes (Sections I, IIA, IIC, VIII, and IX)
(4) NBIC National Board Inspection Code for Boilers and Pressure Vessels (ANSI/NB-23)
(5) API Piping Inspection Code (Inspection, Repair, Alteration and Rerating of In-Service Piping Systems), (API 570).
Abstract
This document presents recommendations for welding chromium-molybdenum steel pipe and tubing to itself and to various other materials. Subjects covered in detail are filler metal selection, joint design, preheating, and postheating. Particular emphasis is placed on the importance of maintaining interpass temperature and dangers inherent in interrupted heating cycles.
  • PinkPant, babakfeyzi, kowheng
  [CivilEA Exclusive] D10.4M-D10.4: GUIDE FOR WELDING AUSTENITIC STAINLESS STEEL PIPING AND TUBING poolmand 0 2,655 02-03-2025, 05:56 AM
  AWS F4.1: SAFE PRACTICES FOR THE PREPARATION OF CONTAINERS AND PIPING FOR WELDING, CU poolmand 0 1,405 01-22-2024, 11:20 AM
  AWS D18.1/D18.1M: SPECIFICATION FOR WELDING OF AUSTENITIC STAINLESS STEEL TUBE AND P poolmand 0 2,413 01-22-2024, 09:43 AM
  AWS D14.7/D14.7M: Recommended Practices for Surfacing and Reconditioning of Industria poolmand 0 1,367 09-09-2023, 12:52 PM
  AWS D10.18M/D10.18: Guide for Welding Ferritic/Austenitic Duplex Stainless Steel Pipi poolmand 0 1,533 09-04-2023, 12:00 PM
  AWS D10.12M/D10.12: Guide for Welding Mild Steel Pipe poolmand 0 1,823 09-04-2023, 11:49 AM
  AWS D10.10/D10.10M: Recommended Practices for Local Heating of Welds in Piping and Tu poolmand 0 1,428 09-04-2023, 11:44 AM
