Civil Engineering Association eBooks Codes, Manual & Handbook AWS AWS A5.4/A5.4M: Specification for Stainless Steel Electrodes for Shielded Metal Arc W
Likes: 8,200 in 1,338 posts
08-22-2023, 07:57 AM
AWS A5.4/A5.4M-2012: Specification for Stainless Steel Electrodes for Shielded Metal Arc Welding
| Size: 1.23 MB| Format: PDF| Quality: Original preprint| Publisher: American Welding Society, Inc. (AWS) | Year: 11th Edition, 2012| pages: 56
[Image: 11219456443671735406.jpg]
AWS A5.4/A5.4M, 11th Edition, 2012 - Specification for Stainless Steel Electrodes for Shielded Metal Arc Welding
This specification prescribes requirements for the classification of covered stainless steel electrodes for shielded metal arc welding.1,2
The chromium content of weld metal deposited by these electrodes is not less than 10.5 percent and the iron content exceeds that of any other element. For purposes of classification, the iron content shall be derived as the balance element when all other elements are considered to be at their minimum specified values.
NOTE: No attempt has been made to classify all grades of filler metals within the limits of the above scope; only the more commonly used grades have been included.
Safety and health issues and concerns are beyond the scope of this standard and, therefore, are not fully addressed herein. Some safety and health information can be found in Annex Sections A5 and A11. Safety and health information is available from other sources, including, but not limited to ANSI Z49.1, Safety in Welding, Cutting and Allied Processes, and applicable state and federal regulations.
This specification makes use of both U.S. Customary Units and the International System of Units [SI]. The measurements are not exact equivalents; therefore, each system must be used independently of the other without combining in any way when referring to material properties. The specification with the designation A5.4 uses U.S. Customary Units. The specification A5.4M uses SI Units. The latter are shown in brackets [] or in appropriate columns in tables and figures. Standard dimensions based on either system may be used for sizing of filler metal or packaging or both under A5.4 or A5.4M specifications.
  • PinkPant, jcbv, babakfeyzi, kowheng
  [CivilEA Exclusive] A5.22 / A5.22M: SPECIFICATION FOR STAINLESS STEEL FLUX CORED AND METAL CORED WELDING poolmand 0 2,467 02-03-2025, 06:02 AM
  [CivilEA Exclusive] D10.4M-D10.4: GUIDE FOR WELDING AUSTENITIC STAINLESS STEEL PIPING AND TUBING poolmand 0 2,575 02-03-2025, 05:56 AM
  AWS A5.12M/A5.12: Specification for Tungsten and Oxide Dispersed Tungsten Electrodes poolmand 1 3,154 09-24-2024, 07:03 AM
  AWS A5.21/A5.21M: Specification for Bare Electrodes and Rods for Surfacing poolmand 1 3,102 05-29-2024, 10:53 AM
  AWS A5.14/A5.14M: Specification for Nickel and Nickel- Alloy Bare Welding Electrodes poolmand 1 3,007 01-27-2024, 11:18 AM
  AWS J1.3/J1.3M: SPECIFICATION FOR MATERIALS USED IN RESISTANCE WELDING ELECTRODES poolmand 0 2,680 01-22-2024, 12:10 PM
  AWS D20.1/D20.1M: SPECIFICATION FOR FABRICATION OF METAL COMPONENTS USING ADDITIVE MA poolmand 0 1,862 01-22-2024, 09:58 AM
