Civil Engineering Association eBooks Codes, Manual & Handbook AWS AWS A5.1/A5.1M: Specification for Carbon Steel Electrodes for Shielded Metal ArcWeld
08-22-2023, 07:38 AM
AWS A5.1/A5.1M-2012: Specification for Carbon Steel Electrodes for Shielded Metal ArcWelding
| Size: 602 KB| Format: PDF| Quality: Original preprint| Year: 2012| pages: 62
AWS A5.1/A5.1M, 14th Edition, 2012 - Specification for Carbon Steel Electrodes for Shielded Metal ArcWelding
This specification prescribes requirements for the classification of carbon steel electrodes for shielded metal arc welding.
Safety and health issues and concerns are beyond the scope of this standard and, therefore, are not fully addressed herein. Some safety and health information can be found in Informative Annex Clauses A5 and A10. Safety and health information is available from other sources, including, but not limited to, ANSI Z49.1, Safety in Welding, Cutting, and Allied Processes,1 and applicable federal and state regulations.
This specification makes use of both U.S. Customary Units and the International System of Units (SI). The measurements are not exact equivalents; therefore, each system must be used independently of the other without combining in any way when referring to material properties. The specification with the designation A5.1 uses U.S. Customary Units. The specification A5.1M uses SI Units. The latter are shown within brackets ([ ]) or in appropriate columns in tables and figures. Standard dimensions based on either system may be used for sizing of filler metal or packaging or both under A5.1 or A5.1M specifications.
1 ANSI Z49.1 is published by the American Welding Society, 8669 Doral Blvd., Doral, FL 33166
  • PinkPant, babakfeyzi, kowheng
  [CivilEA Exclusive] A5.22 / A5.22M: SPECIFICATION FOR STAINLESS STEEL FLUX CORED AND METAL CORED WELDING poolmand 0 2,550 02-03-2025, 06:02 AM
  AWS A5.12M/A5.12: Specification for Tungsten and Oxide Dispersed Tungsten Electrodes poolmand 1 3,220 09-24-2024, 07:03 AM
  AWS A5.21/A5.21M: Specification for Bare Electrodes and Rods for Surfacing poolmand 1 3,184 05-29-2024, 10:53 AM
  AWS A5.14/A5.14M: Specification for Nickel and Nickel- Alloy Bare Welding Electrodes poolmand 1 3,080 01-27-2024, 11:18 AM
  AWS J1.3/J1.3M: SPECIFICATION FOR MATERIALS USED IN RESISTANCE WELDING ELECTRODES poolmand 0 2,764 01-22-2024, 12:10 PM
  AWS D20.1/D20.1M: SPECIFICATION FOR FABRICATION OF METAL COMPONENTS USING ADDITIVE MA poolmand 0 1,942 01-22-2024, 09:58 AM
  AWS D18.1/D18.1M: SPECIFICATION FOR WELDING OF AUSTENITIC STAINLESS STEEL TUBE AND P poolmand 0 2,452 01-22-2024, 09:43 AM
