Civil Engineering Association eBooks Codes, Manual & Handbook ACI [CivilEA Exclusive] ACI 355.2: Post-Installed Mechanical Anchors in Concrete—Qualification Requir
12-11-2022, 06:12 AM (This post was last modified: 12-15-2024, 06:03 AM by poolmand.)
ACI CODE-355.2-22: Post-Installed Mechanical Anchors in Concrete—Qualification Requirements and Commentary
Author(s)/Editor(s): ACI Committee 355 | Size: 3.69 MB| Format: PDF| Quality: Original preprint| Year: 2022| pages: 102 | ISBN: 9781641951920
[Image: 19249623635874352394.jpg]
ACI CODE-355.2 prescribes testing programs and evaluation requirements for post-installed mechanical anchors intended for use in structural applications addressed by ACI 318 and subjected to static or seismic loads in tension, shear, or combined tension and shear. Criteria are prescribed for determining whether anchors are acceptable for use in uncracked concrete only, or in cracked as well as uncracked concrete. Performance categories for anchors are established, as are the criteria for assigning anchors to each category. The anchor performance categories are used by ACI 318 to assign capacity reduction factors and other design parameters.
anchors; cracked concrete; expansion anchors; fasteners; mechanical anchors; post-installed anchors; screw anchors; undercut anchors.
[-] The following 12 users Like poolmand's post:12 users Like poolmand's post
  • PinkPant, blaze, jcbv, cace-01, Dell_Brett, babakfeyzi, Umer.Aleem, subin91, milova, kowheng, malc, ascetic19
ACI CODE-355.2-24: Post-Installed Mechanical Anchors in Concrete—Qualification Requirements and Commentary
| Format: PDF| Quality: Scanner| Year: 2024| pages: 118 | ISBN: 9781641952682
[Image: 21842056712756539920.jpg]
This Code prescribes testing programs and evaluation requirements for post-installed mechanical anchors intended for use in structural applications addressed by ACI CODE-318 and subjected to static or seismic loads in tension, shear, or combined tension and shear. Criteria are prescribed for determining whether anchors are acceptable for use in uncracked concrete only, or in cracked as well as uncracked concrete. Performance categories for anchors are established, as are the criteria for assigning anchors to each category. The anchor performance categories are used by ACI CODE-318 to assign capacity reduction factors and other design parameters.
  • babakfeyzi, lisine
  [CivilEA Exclusive] ACI 355.5: Post-Installed Reinforcing Bar Systems in Concrete—Qualification Requireme poolmand 0 787 12-06-2025, 11:37 AM
  ACI 355.4: Qualification of Post-Installed Adhesive Anchors in Concrete and Comment Mohammad6299 3 3,523 12-14-2024, 12:54 PM
  ACI SP-314: Eco-Efficient and Sustainable Concrete Incorporating Recycled Post-Consum poolmand 0 1,485 03-04-2024, 07:34 AM
  ACI 364.8: Hydrodemolition for Concrete Removal in Unbonded Post-Tensioned Systems poolmand 0 1,276 05-02-2023, 11:55 AM
