Civil Engineering Association eBooks Codes, Manual & Handbook AASHTO AASHTO T84: Standard Method of Test for Specific Gravity and Absorption of Fine A
12-11-2022, 05:55 AM (This post was last modified: 01-15-2024, 09:08 AM by Administrator.)
AASHTO T 84-22: Standard Method of Test for Specific Gravity and Absorption of Fine Aggregate
| Size: 335 KB| Format: PDF| Quality: Original preprint| Publisher: AASHTO| Year: January 2022| pages: 11
AASHTO T 84, 2022 Edition, 2022 - Standard Method of Test for Specific Gravity and Absorption of Fine Aggregate
This method covers the determination of bulk and apparent specific gravity, 23/23°C (73.4/73.4°F), and absorption of fine aggregate.
This method determines (after 15–19 h of soaking in water) the bulk specific gravity and the apparent specific gravity, the bulk specific gravity on the basis of mass of saturated surface-dry (SSD) aggregate, and the absorption.
The values stated in SI units are to be regarded as the standard.
This standard may involve hazardous materials, operations, and equipment. This standard does not purport to address all of the safety concerns associated with its use. It is the responsibility of the user of this procedure to consult and establish appropriate safety and health practices and to determine the applicability of regulatory limitations prior to its use.
The quality of the results produced by this standard are dependent on the competence of the personnel performing the procedure and the capability, calibration, and maintenance of the equipment used. Agencies that meet the criteria of R 18 are generally considered capable of competent and objective testing/sampling/inspection/etc. Users of this standard are cautioned that compliance with R 18 alone does not completely assure reliable results. Reliable results depend on many factors; following the suggestions of R 18 or some similar acceptable guideline provides a means of evaluating and controlling some of those factors.
[-] The following 7 users Like poolmand's post:7 users Like poolmand's post
  • PinkPant, Dell_Brett, babakfeyzi, subin91, milova, kowheng, malc
  AASHTO M259: Standard Specification for Precast Reinforced Concrete Monolithic Box Se poolmand 1 3,250 09-23-2024, 10:15 AM
  AASHTO R69: Standard Practice for Determination of Long-Term Strength for Geosyntheti poolmand 0 2,904 01-15-2024, 09:01 AM
  AASHTO M351: Standard Specification for Cotton Duck Fabric Bridge Bearings, poolmand 0 2,895 01-15-2024, 08:42 AM
  AASHTO M270M/M270: Standard Specification for Structural Steel for Bridges poolmand 0 2,802 01-15-2024, 08:34 AM
  AASHTO M207M/M207: Standard Specification for Reinforced Concrete Elliptical Culver poolmand 0 2,689 01-08-2024, 05:25 AM
  AASHTO T85: Standard Method of Test for Specific Gravity and Absorption of Coarse poolmand 0 2,885 12-11-2022, 06:01 AM
  AASHTO - Standard Specifications for Structural Supports for Highway Signs, Luminaire jamildear4u 6 7,053 01-25-2022, 10:57 AM
