Civil Engineering Association Software Software Product Non Engineering Software dbForge Studio 2022 for SQL Server Enterprise 6.2.22 (x64)
 straightrun65
User ID: 179491
Threads: 20
Likes: 14 in 12 posts
Given Likes: 0
07-02-2022, 03:04 PM (This post was last modified: 07-02-2022, 10:40 PM by Dell_Brett.)
File size: 136 MB
SQL developers and DBAs performing complex database tasks can use the GUI tool to speed up almost any database experience, such as designing databases, writing SQL code, comparing databases, synchronizing schemas and data, generating meaningful test data, and much more.
There is no need to waste time searching for or purchasing SQL Server Management Studio (SSMS) plug-ins across the Internet to get your work done - dbForge Studio for SQL Server has everything you need to set up your SQL development environment. Check out the great advantages of our SSMS alternative and make sure you are just one step away from having the best user experience with this MS SQL database client!
Database Development
dbForge Studio for MS SQL Server provides extensive functionality and a bunch of built-in tools that will automate routines and make developers truly agile in the database development process.
Capabilities
Edit and run queries in a new SQL document
Build queries in a visual designer
Run a large script without loading it into memory
Create unit tests using tSQLt framework
Debug stored procedures and functions
Source-control database changes
Create database objects in a visual editor
Generate database scripts
Database Management
As a robust Microsoft SQL manager, dbForge Studio for SQL Server has a set of database management tools that help DBAs to protect data and resolve problems before they harm your database health.
Capabilities
Compare and synchronize database schemas
Compare and synchronize data of two databases
Copy databases
Generate docs in HTML, PDF, or Markdown formats
Create schema snapshots
Generate test data and instantly populate a database
Export/import table data to a file (CSV, Excel, XML, etc.)
HOMEPAGE
DOWNLOAD RAPIDGATOR
DOWNLOAD UPLOADGIG
  dbForge Studio 2020 for MySQL Enterprise 9.0.897 (x64) straightrun65 0 1,788 07-02-2022, 02:42 PM
Last Post: straightrun65
  ABViewer Enterprise 11.0.0.12 (x86/x64) ibg0203 1 4,545 10-21-2015, 03:14 PM
Last Post: ibg0203
