Civil Engineering Association eBooks Codes, Manual & Handbook ACI ACI 350: Code Requirements for Environmental Engineering Concrete Structures (ACI
12-06-2021, 09:39 AM (This post was last modified: 12-07-2021, 12:05 PM by Administrator.)
ACI 350-20: Code Requirements for Environmental Engineering Concrete Structures (ACI 350-20) and Commentary (ACI 350R-20)
Author(s)/Editor(s): ACI Committee 350 | Size: 100 MB| Format: PDF| Quality: Original preprint| Year: 2021| pages: 544 | ISBN: 9781641951517
[Image: 93613695961763773115.jpg]
The “Code Requirements for Environmental Engineering Concrete Structures” (Code) portion of this document covers the structural design, materials selection, and construction of environmental engineering concrete structures. Such structures are used for conveying, storing, or treating water and wastewater, other liquids, and solid waste. The term “solid waste” as used in the Code encompasses the heterogeneous mass of disposed-of materials, as well as more homogeneous agricultural, industrial, and mineral wastes.
The Code also covers the evaluation of existing environmental engineering concrete structures.
Environmental engineering concrete structures are subject to uniquely different loadings and severe exposure conditions that require more restrictive serviceability requirements and may provide longer service lives than non-environmental structures.
Loadings include normal dead and live loads, earth pressure loads, hydrostatic and hydrodynamic loads, and vibrating equipment loads. Exposures include concentrated chemicals, alternate wetting and drying, high-velocity flowing liquids, and freezing and thawing of saturated concrete. Serviceability requirements include liquid-tightness, gas-tightness, and durability.
Proper design, materials, and construction of environmental engineering concrete structures are required to produce serviceable concrete that is dense, durable, nearly impermeable, and resistant to relevant chemicals, with limited deflections and cracking. This includes minimizing leakage and control over the infiltration of, or contamination to, the environment or groundwater.
The Code presents additional material as well as modified portions of the ACI 318-05, ACI 318-08, and ACI 318-11 building codes that are applicable to environmental engineering concrete structures.
The Commentary discusses some of the considerations of the committee in developing the ACI 350 Code, and its relationship with ACI 318. Emphasis is given to the explanation of provisions that may be unfamiliar to some users of the Code. References to much of the research data referred to in preparing the Code are given for those who wish to study certain requirements in greater detail.
The chapter and section numbering of the Code are followed throughout the Commentary.
Among the subjects covered are: drawings and specifications, inspections, materials, concrete quality, mixing and placing, forming, embedded pipes, joints, reinforcement details, analysis and design, strength and serviceability, flexural and axial loads, shear and torsion, development of reinforcement, slab systems, walls, footings, precast concrete, prestressed concrete, shell structures, folded plate members, provisions for seismic design, and an alternate design method in Appendix A.
The quality and testing of materials used in the construction are covered by reference to the appropriate standard specifications. Welding of reinforcement is covered by reference to the appropriate AWS standard. Criteria for liquid-tightness and gas-tightness testing may be found in ACI 350.1.
chemical attack; coatings; concrete durability; concrete finishing (fresh concrete); concrete slabs, crack width and spacing; cracking (fracturing); environmental engineering; hydraulic structures; inspection; joints (junctions); joint sealers; liners; liquid; patching; permeability; pipe columns; pipes (tubes); prestressed concrete; prestressing steels; protective coatings; reservoirs; roofs; serviceability; sewerage; solid waste facilities; tanks (containers); temperature; torque; torsion; vibration; volume change; walls; wastewater treatment; water; water-cementitious materials ratio; water supply; water treatment.
[-] The following 17 users Like poolmand's post:17 users Like poolmand's post
  • Administrator , civilfafa, babakfeyzi, cheosmith, Dell_Brett, mohamz, kowheng, simanta, zrilek, spat, Umer.Aleem, araza023, PinkPant, subin91, jonygut, kristoffer_89, joker™
  ACI 318.2: Building Code Requirements for Concrete Thin Shells ir_71 7 5,969 12-06-2025, 11:30 AM
  [CivilEA Exclusive] ACI/PCI 319: Structural Precast Concrete —Code Requirements and Commentary poolmand 2 7,361 09-16-2025, 11:03 AM
  ACI 318: Building Code Requirements for Structural Concrete and Commentary robertsas 81 46,217 08-17-2025, 10:45 AM
  [CivilEA Exclusive] ACI 349: Code Requirements for Nuclear Safety Related Concrete Structures andersen3 5 5,698 12-15-2024, 06:33 AM
  [CivilEA Exclusive] ACI 323: Low-Carbon Concrete - Code Requirements and Commentary poolmand 0 2,300 12-15-2024, 05:50 AM
  ACI 350.1: Tightness Testing of Environmental Engineering Concrete Structures Dell_Brett 8 7,292 02-03-2024, 06:37 AM
  ACI 307: Requirements for Reinforced Concrete Chimneys—Code and Commentary poolmand 0 2,652 02-03-2024, 06:28 AM
