Civil Engineering Association Software Software Product Bentley Products Bentley RAM Elements CONNECT Edition V16 Update 5 v16.05.00.213 x64
11-23-2021, 07:08 AM
Tackle projects with confidence and efficiently produce high quality and economical designs, using various concrete, steel, and joist building materials; all in compliance with your local building codes. Quickly design, analyze, and create documentation for your building projects, saving time and money. Design anything from individual components to large-scale building and foundations. Increase your productivity by eliminating tedious and time consuming tasks with RAM’s practical applications. RAM maximizes your software investment with one fully integrated application suite offering complete building analysis, design, and drafting for both steel and concrete structures. Easily share your structural data with applications such as Revit, Tekla, and Bentley’s AECOsim Building Designer through Integrated Structural Modeling (ISM) workflows.
Capabilities
- Analyze gravity and lateral load
Design and analyze simple or complex structures for a wide range of loading conditions, including those induced by gravity such as dead and live loads, including skip conditions, in combination with lateral loads including wind and seismic.
- Comply with seismic requirements
Design and detail seismic force-resisting systems, generating seismic loads according to the relevant building code. Consider these forces in the design of elements and, where applicable, the design of frames and the larger structural system. Enforce the ductility requirements of the selected design code in element proportioning and detailing.
- Design and analyze with finite elements
Complete building analysis, design, and drafting for the entire structure accurately and efficiently using our state-of-the-art finite element analysis. Reduce or eliminate the time spent waiting for results using our fast solvers.
- Design and analyze structural models
Quickly model your entire structure, including decks, slabs, slab edges and openings, beams, columns, walls, braces, spread and continuous footings, and pile caps. Efficiently automate many of your time-consuming design and analysis tasks and produce practical system and component designs that are document ready.
- Design to international design standards
Extend the reach of your business practice and take advantage of global design opportunities by using a wide range of international standards and specifications in our design products. Complete your designs with confidence thanks to extensive support of U.S. and international standards.
[Image: homepage.png]
[-] The following 8 users Like poolmand's post:8 users Like poolmand's post
  • Dell_Brett, Administrator , mgdario, rami1976, zrilek, PinkPant, caifan, structural
  STAAD.Pro CONNECT Edition Update 3 (21.03.00.146) RajaK 7 12,095 07-27-2024, 03:40 AM
  Bentley MicroStation CONNECT Edition 2023 poolmand 2 5,889 10-08-2023, 12:24 PM
  Bentley RAM Elements v23 poolmand 0 3,776 10-04-2023, 08:33 AM
  Bentley STAAD.Pro CONNECT V23 poolmand 0 5,966 10-02-2023, 09:01 AM
  Bentley STAAD.Pro CONNECT Edition V22 kirankumarklk 12 21,951 07-05-2023, 07:52 AM
Last Post: Arigato
  Bentley.RCDC.Connect.Edition.11.02.00.200 kirankumarklk 0 4,780 04-02-2022, 11:14 AM
Last Post: kirankumarklk
  RCDC FE Connect Edition V4 Update 1 RajaK 1 6,714 03-28-2022, 06:28 AM
