Civil Engineering Association Software Software Product Bentley Products Bentley OpenRail Designer CONNECT Edition 2021
11-01-2021, 07:11 AM
Bentley OpenRail Designer CONNECT Edition 2021 R1 Update 10 (Build 10.10.01.03) x64
[Image: 02172767984549466170.jpg]
[Image: 54337398259456271343.jpg]
[Image: 43598689578717152074.jpg]
[Image: 55052411839416379960.jpg]
OpenRail Designer introduces a new, comprehensive modeling environment for streamlined project delivery of rail network assets. This environment unifies design and construction from concept through commissioning and completion. The application delivers a high performance, immersive, 3D modeling environment that enables instantaneous and interactive parametric modeling of rail corridors.
OpenRail Designer provides modeling and design capabilities for metro, light rail, commuter rail, or high-speed rail design projects. You can save time on the design and maintenance of track, station, and yard design while significantly increasing productivity.
Bring real-world settings to your project by gathering context data quickly from a variety of sources, such as point clouds, 3D reality meshes, terrain data, images, and geospatial information.
Enable project information sharing across teams, locations, and disciplines with precision and security.
Perform regression analysis, horizontal and vertical alignment, cant design, and turnout placement to international standards.
Improve asset quality and reduce rework with a fully localized application.
Share realistic visualizations with the public and stakeholders to gather feedback, improve public engagements, and speed project approvals.
  • Dell_Brett, Administrator , PinkPant, oanm2000
02-26-2022, 09:13 AM
Bentley OpenRail Designer CONNECT Edition 2021 R2 Update 10 (Build 10.10.20.078) x64
OpenRail Designer is a comprehensive, multi-discipline 3D modeling application to advance the delivery of rail network projects from planning through performance. This new application handles a wide variety of complex tasks such as regression analysis, cant (rail Superelevation) calculations, turnout and switch placement, yard and station design, site development, road design, tunnels, sanitary and stormwater network design, overhead line electrification (future release) and production of construction deliverables.
OpenRail Designer CONNECT Edition is a new application that replaces the capabilities of all applications in the Bentley Rail Track, Power Rail Track and Power Rail Overhead Line for Civil product lines in a single offering. OpenRail Designer is built on OpenRoads modeling technology and will provide significant new design modeling, analytical modeling and project collaboration capabilities.
Below are highlights of the capabilities of OpenRail Designer CONNECT edition.
- Progressive Conceptual Design. Users can directly progress conceptual designs created with OpenRail ConceptStation, preserving all work and data. OpenRail ConceptStation enables rapid conceptual and preliminary design, leveraging existing context captured through reality meshes, point clouds, GIS, and other sources, and creating compelling presentations with engineering precision.
- Comprehensive Rail Track Design. OpenRail Designer is a complete rail design application that enables users to create intelligent geometric and 3D models containing track information, terrain data, turnouts, crossings, dynamic regression, speed tables, cant, sleeper placement, ballast, sub-ballast, tunnels, signals, and related site features.
- Design Rail Overhead Line System. Use local standards and geometry of the underlying track to make span calculations, locate foundation locations, and calculate height and stagger values for your wire runs. Parametric design capabilities enable modeling of cantilever sets, masts, and portals. Produce schematics and 3D models of your OLE system. (available in future release)
- Multi-discipline Support. OpenRail Designer integrates support for each discipline with specific user profiles dedicated to each discipline. Users can switch discipline perspectives, for instance from Rail Design profile to Subsurface Utility profile.
- Reality Modeling Tools. OpenRail Designer includes a fully-functioned toolset to incorporate and edit all reality modeling data types, including the capability to extract ground-level features from reality meshes and LiDAR, as well as to reference point clouds and imagery.
- Geotechnical Tools. Connect directly to gINT geotechnical databases to incorporate subsurface terrain details into their models for improving grading and piling. Subsurface terrains can be generated or modeled based on the bore hole materials and projected in road, rail, and drainage profiles, sections, and plans.
- Subsurface Utilities. Users can select from a large catalog of functional components for utility and drainage to model underground drainage and utility networks. Drainage models can be optimized for water flow using integrated water analysis tools, with results available in data tables or visually in a profile view.
- Rich Deliverables. An expanded set of deliverables range from traditional plan sets and animations to digital construction models—for automated machine control and field positioning systems including for excavation, grading, and piling.
- Live Plan Generation. Plan generation is no longer a separate process limited to a point in time. Settings and annotations are dynamically updated and live in the model. Views are saved with specific display rules and sheet index embedded, making it easy to navigate between model and drawings. Up-to-date drawings can be generated automatically at any time, creating a natural and fluid design environment for both modeling and detailing.
- Enlivened Visualization. OpenRail Designer provides direct integration to Bentley LumenRT for producing cinematic visualization, adding vegetation, reflecting nature and climate.
[Image: homepage.png]
  • Dell_Brett, rami1976, PinkPant, oanm2000
  Bentley OpenRail ConceptStation v24 poolmand 0 2,655 10-20-2024, 08:43 AM
  STAAD.Pro CONNECT Edition Update 3 (21.03.00.146) RajaK 7 12,115 07-27-2024, 03:40 AM
  Bentley MicroStation CONNECT Edition 2023 poolmand 2 5,900 10-08-2023, 12:24 PM
  Bentley STAAD.Pro CONNECT V23 poolmand 0 5,982 10-02-2023, 09:01 AM
  Bentley STAAD.Pro CONNECT Edition V22 kirankumarklk 12 22,015 07-05-2023, 07:52 AM
Last Post: Arigato
  Bentley.RCDC.Connect.Edition.11.02.00.200 kirankumarklk 0 4,791 04-02-2022, 11:14 AM
Last Post: kirankumarklk
  RCDC FE Connect Edition V4 Update 1 RajaK 1 6,721 03-28-2022, 06:28 AM
