Civil Engineering Association Software Software Product Bentley Products WaterGems CONNECT 10.03.02.75
10-02-2021, 06:58 AM
[Image: screen.png][/align]
[Image: 18181830850725001200.png]
OpenFlows WaterGEMS provides you with a comprehensive yet easy-to-use decision-support tool for water distribution networks. The software helps improve your knowledge of how infrastructure behaves as a system, how it reacts to operational strategies, and how it should grow as population and demands increase.
From fire flow and water quality simulations, to criticality and energy cost analysis, OpenFlows WaterGEMS has everything you need in a flexible multiplatform environment.
OpenFlows WaterGEMS provides numerous software capabilities for:
Intelligent planning for system reliability: The capability of the water network to adequately serve its customers must be evaluated whenever system growth is anticipated. With OpenFlows WaterGEMS, effectively identify potential problem areas, accommodate service area growth, and plan capital improvements.
Optimized operations for system efficiency: Realistically modeling the operation of complex water systems can be difficult. With OpenFlows WaterGEMS, model pumps accurately, optimize pumping strategies, and plan shutdowns and routine operations to minimize disruption.
Reliable asset renewal decision support for system sustainability: When it comes time to renew or replace your water infrastructure, the amount of asset-related information you must consider can be overwhelming. OpenFlows WaterGEMS capabilities such as Pipe Renewal Planner makes the task much easier by analyzing and comparing a wide range of variables to prioritize renewal decisions.
OpenFlows WaterGEMS is a superset of OpenFlows WaterCAD.
[Image: homepage.png]
[-] The following 7 users Like poolmand's post:7 users Like poolmand's post
  • Administrator , cace-01, Dell_Brett, rami1976, subin91, deovrat, spat
 deovrat
User ID: 35484
Threads: 2
Likes: 6 in 2 posts
Given Likes: 5
10-18-2021, 04:53 AM
Hi, thanks for the update. The product gets activated well. But it says it is valid only for 250 pipes. Is that a limitation or it should work >250 pipes too?
  WaterGEMS CONNECT Edition 10.00.00.49 TAFATNEB 1 6,085 12-02-2016, 01:02 PM
  Bentley WaterCAD & WaterGEMS V8i SS6 08.11.06.58 er.shyams 1 7,556 02-22-2016, 07:08 PM
Last Post: cvidalv
  Bentley WaterGEMS v8i Select series 5(08.11.05.61) emmi 2 10,455 09-28-2015, 08:38 PM
Last Post: joker™
  Bentley WaterGEMS V8i (SELECtseries) 4 08.11.04.50 BennyP 1 6,378 11-21-2013, 09:40 AM
Last Post: jonny78
  Bentley WaterGEMS V8i (SELECT series 2) 08.11.02.31 BennyP 6 15,088 01-24-2013, 07:24 AM
Last Post: joker™
  Bentley WaterGEMS XM v08.09.400.34 kulas1987 0 4,883 08-06-2010, 03:20 PM
Last Post: kulas1987
  Bentley WaterGEMS V8i (SelectSERIES 1) 05.11.01.32 (Trial) BennyP 0 5,247 07-13-2010, 03:31 PM
