Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Books and Codes Request [REQUEST] Design Guide for Reinforced Concrete Diaphragms
[Request] Design Guide for Reinforced Concrete Diaphragms
 toddyi
Junior Member
User ID: 396
Threads: 3
Likes: 18 in 5 posts
Given Likes: 39
09-24-2019, 09:59 AM (This post was last modified: 09-25-2019, 07:01 AM by lisine. Edit Reason: Link added )
Design Guides, Key Publications
Design Guide - 2019
224 pp.; 1st edition
Contents include:
Introduction
Materials
Determining the Diaphragm Thickness
Diaphragm Design Forces
Load Combinations
Diaphragm Modeling and Analysis
Design Strength
Determining and Detailing the Required Reinforcement
Design Procedure
Examples
References
This guide is the definitive resource on the design and detailing of diaphragms in cast-in-place reinforced concrete buildings. The requirements in ACI 318-14 are clearly summarized in figures and tables for quick reference. Comprehensive methods are provided on how to (1) determine diaphragm thickness based on strength and serviceability requirements; (2) calculate in-plane and collector forces based on ASCE/SEI 7-16 requirements; (3) model and analyze diaphragms; (4) determine the required reinforcement based on two different types of common construction methods; and (5) economically detail the required reinforcement based on the latest ACI 318 requirements. A step-by-step design procedure is provided that can be used for buildings assigned to Seismic Design Categories A through F. Numerous design aids and worked-out examples illustrate the code requirements for low-, mid-, and high-rise buildings, including buildings with irregularities.
[-] The following 9 users Like toddyi's post:9 users Like toddyi's post
  • sabooryan, RyanRS, emma101, hatkam, RICARDI, simanta, carolinandra, adams, jonygut
  [REQUEST] AASHTO LRFD Bridge Design Specifications for GFRP-Reinforced Concrete, 2nd Edition whysx 1 1,748 08-30-2023, 08:59 AM
  [REQUEST] Guide Specifications for the Design of Concrete Bridge Beams Prestressed with Carbon whysx 1 1,694 08-30-2023, 06:19 AM
  [REQUEST] Reinforced concrete design workflow to eurocode 2 anneb361 2 1,845 04-13-2022, 04:39 PM
Last Post: anneb361
  [REQUEST] CRSI Design Guide for Vibrations of Reinforced Concrete Floor Systems gulilero 3 3,339 02-28-2022, 11:45 AM
Last Post: bigone
  [REQUEST] MNL-17(21) - ACI Reinforced Concrete Design Handbook (A companion to ACI 318-19) aslam 9 4,657 05-17-2021, 12:49 PM
Last Post: deviationz
  [REQUEST] ACI 544.6R-15 Report on Design and Construction of Steel Fiber-Reinforced Concrete El aslam 2 2,127 01-08-2019, 02:45 AM
Last Post: concreteok
  [REQUEST] Reinforced Concrete Design: To Eurocode 2 , seventh edition zeljko2 7 4,825 08-11-2018, 07:44 AM
Last Post: gianniorlati
