Civil Engineering Association eBooks Codes, Manual & Handbook Hydraulic Institute ANSI/ HI Standards (Pumping)
 malc
User ID: 30599
Threads: 66
Likes: 1,520 in 155 posts
Given Likes: 15191
07-31-2018, 10:12 AM
Author(s)/Editor(s): ANSI/HI | Size: 78.6 MB | Format: PDF | Quality: Original preprint | Publisher: ANSI/HI | Year: Varies | pages: Volumes | ISBN: As Shown
[Image: 95387208676017211703.jpg]
7.6 Erratum 7.6-2013
9.6.4 erratum 3 page-10-Vibration Measurements 2009
9.8 Erratum 9.8-2015
ANSI_HI  1.1-1.2-2008 Rotodynamic Centrifugal Pumps Nomenclature Definitions
ISBN 978-1-880952-84-9
ANSI_HI  1.3-2013 Rotodynamic Centrifugal Pumps Design Applications
ISBN 978-1-935762-16-4
ANSI_HI  1.4-2010 Rotodynamic Centrifugal Pumps Installation Operation Maintenance
ISBN 978-1-880952-86-3
ANSI_HI  2.1-2.2-2008 Rotodynamic Vertical Pumps Nomenclature Definitions
ISBN 978-1-880952-85-6
ANSI_HI  2.1–2.2-2014 Rotodynamic Vertcal Pumps Radial Axial Mixed Flow Nom Defs
ISBN 978-1-935762-14-0
ANSI_HI  2.3-2013 Rotodynamic Vertical Pumps Radial Mixed Axial Flow Design Applications.
ISBN 978-1-935762-17-1
ANSI_HI  2.4-2008 Rotodynamic Vertical Pumps Installation Operation Maintenance
ISBN 978-1-880952-87-0
ANSI_HI  3.1-3.5-2008 Rotary Pumps Nomenclature Definitions Application Operation
ISBN 978-1-880952-80-1
ANSI_HI  3.6-2010 Rotary Pumps Tests
ISBN 978-1-880952-81-8
ANSI_HI  4.1-4.6-2010 Sealless Magnetically driven Pumps
ISBN 978-1-935762-00-3
ANSI_HI  5.1-5.6-2010 Sealless Rotodynamic Pumps Nom Def Apps Oper Tests
ISBN 978-1-880952-92-4
ANSI_HI  6.1-6.5-2000 Reciprocating Power Pumps Nom Defs Apps Op
ISBN 1-880952-39-4
ANSI_HI  6.6-2000 Reciprocating Pumps Tests
ISBN 1-880952-40-8
ANSI_HI  7.1-7.5-2013 Controlled Volume Metering Pumps Nom Defs Apps Op
ISBN 978-1-935762-09-6
ANSI_HI  7.6-2012 Controlled Volume Metering Pumps Tests
ISBN 978-1-935762-08-9
ANSI_HI  8.1-8.5-2000 Direct Acting Steam Pumps Nom Defs Apps Op
ISBN 1-880952-42-4
ANSI_HI  9.1-9.5-2000 Pumps General Guidelines Types Defs Apps Meas Decont
ISBN 1-880952-43-2
ANSI_HI  9.6.1-2012 Rotodynamic Pumps Guideline NPSH Margin
ISBN 978-1-935762-10-2
ANSI_HI  9.6.2-2011  Rotodynamic Pumps Assmt Applied Nozzle Loads
ISBN 978-1-935762-06-5
ANSI_HI  9.6.3-2012 Rotodynamic Centrifugal and Vertical Pumps Allow Oper Region
ISBN 1-880952-91-2
ANSI_HI  9.6.4-2009 Rotodynamic Pumps Vibration Measurement Allow
ISBN 978-1-880952-82-5
ANSI_HI  9.6.5-2009 Rotodynamic Centrifugal and Vertical Pumps Condition Monitoring
ISBN 978-1-880952-89-4
ANSI_HI  9.6.6-2009 Rotodynamic Pumps - Pump Piping
ISBN 978-1-880952-60-3
ANSI_HI  9.6.7-2010 Rotodynamic Centrifugal and Vertical Pumps Effects Liquids Viscosity Pertormance
ISBN 978-1-935762-04-1
ANSI_HI  9.6.9-2013 Rotary Pumps Condition Monitoring
ISBN 978-1-935762-20-1
ANSI_HI  9.8-2012 Rotodynamic Pumps - Pump Intake Design
ISBN 978-1-880952-70-2
ANSI_HI  10.1-10.5-2010 Air Operated Pumps Nom Defs Apps Op
ISBN 978-0-9824330-1-0
ANSI_HI  10.6-2010 Air Operated Pumps Tests
ISBN 978-0-9824330-2-7
[-] The following 11 users Like malc's post:11 users Like malc's post
  • rami1976, blaze, febo927, PinkPant, amindoxiti, pedzaquino, oanm2000, emmi, karthikeyans3d, BLESSED DOVE, Dell_Brett
  Pumping Manual International: Handbook of Pumps and Pumping ska51 0 1,834 07-03-2011, 06:10 PM
Last Post: ska51
  Concrete Pumping Code of Practice 2005 ir_71 0 2,241 02-12-2011, 06:48 AM
