Civil Engineering Association eBooks General Books EEMUA Publications
EEMUA Publications
 malc
User ID: 30599
Threads: 66
Likes: 1,520 in 155 posts
Given Likes: 15191
Points:15,026 EP
07-31-2018, 09:49 AM
EEMUA Publications
Author(s)/Editor(s): EEMUA | Size: 37.2 MB | Format: PDF | Quality: Original preprint | Publisher: EEMUA | Year: Varies | pages: Volumes | ISBN: As shown
[Image: 74557584688883733586.jpg]
Factory stairways, ladders and handrails Including access platforms and ramps
EEMUA PUBLICATION 105
Edition 8
ISBN 978 0 85931 200 4
This Publication gives recommendations and typical details for the design and general construction of factory stairways, ladders, access platforms, ramps and handrails. It is primarily intended for use by engineers and architects responsible for the preparation of detail drawings for the construction and installation of this ancillary equipment. Its scope covers the design, construction, maintenance and inspection of such equipment.
Recommendations for refrigerated liquefied gas storage tanks
EEMUA PUBLICATION 147
Edition 3
ISBN 978 0 85931 213 4
The purpose of this EEMUA Publication is to supply the outline information necessary for the categorisation, inspection and maintenance of single, double and full containment tanks for the bulk storage of refrigerated liquefi ed gases down to -165°C, and essentially at atmospheric pressure. Liquids covered by the scope of this document include Liquefi ed Petroleum Gas (LPG), ethylene, ethane, Liquefi ed Natural Gas (LNG) and similar hydrocarbons, together with ammonia.
GUIDANCE TO OWNERS ONDEMOLITION OF VERTICAL CYLINDRICAL STEEL STORAGE TANKS AND STORAGE SPHERES
EEMUA PUBLICATION No 154 : 2002
2nd. Edition
ISBN N/A
EEMUA 154 was first published in 1989. In line with the present EEMUA policy of assessing the currency of its publications every five years, the Storage Tanks Technical Committee, which is responsible for the document‘s upkeep, has undertaken a comprehensive review of the document, and prepared this revised, second edition. The new edition has been expanded to include guidance on the demolition of both damaged tanks and storage spheres. A number of photographs are also included, and the bibliography expanded.
Construction Specification for fixed offshore structures.
EEMUA PUBLICATION 158
Edition 3
ISBN 978 0 85931 202 8
This Specification was originally developed by the EEMUA Materials for Offshore Service (MOS) technical committee in 1991 and covered the construction of fixed offshore steel structures for installation primarily within the United Kingdom Continental Shelf. Though the original document was created for use in the North Sea, it has been applied successfully in other locations. Therefore changes in this 3rd Edition now reflect the global nature of the offshore oil and gas industry, with the Specification having a much broader applicability. Furthermore, wind turbine installations now constitute a significant proportion of new constructions offshore.
Above ground flat bottomed storage tanks Guide to inspection, maintenance and repair
EEMUA PUBLICATION 159
Edition 4
ISBN 978 0 85931 205 9
In addition to improving the logical sequence of the subject matter, this Edition contains appendices offering additional guidance on how to perform assessment calculations on tank components, illustrated by means of sample calculations, as well as on repair methods. It also includes various new Sections such as that on risk and reliability-based maintenance (herein termed Probabilistic Preventive Maintenance―PPM), a subject that is given comprehensive coverage.
A guide to the pressure testing of in-service pressurised equipment.
EEMUA PUBLICATION 168
Edition 2
ISBN 978 0 85931 181 6
The Guide gives practical advice on the testing and inspection which may be carried out once the service life of pressure equipment has begun, but excluding the initial installation and commissioning. It is applicable to all types of nontransportable industrial pressure equipment and systems, including pressure vessels and pipework.
SPECIFICATION FOR STRUCTURAL CASTINGS FOR USE OFFSHORE.
EEMUA PUBLICATION No 176 : 1998
ISBN O 85931 061 2
This Specification has been prepared by the EEMUA Materials for Offshore Service Technical Committee as a joint Supplier-Purchaser document for the procurement of carbon-manganese steel castings for use as structural members of offshore platforms for location in the North Sea. The Specification may also be used at the discretion of purchasers of castings for application in other geographic areas, but it would be necessary in such circumstances to take into account any alternative and/or supplementary requirements of local statutory regulations and authorities.
Frangible Roof Joints for Fixed Roof Storage Tanks:Guide for designers and users.
EEMUA PUBLICATION 180
Edition 2
ISBN 0 85931 161 9
This Publication has been developed by the EEMUA Storage Tanks Technical Committee to give guidance to designers and users of fixed roof vertical cylindrical storage tanks on methods of ensuring that, in the event of vapour over-pressure, tank failure occurs preferentially at the roof-to-shell joint. This Publication covers the essential features both for new structures and for the modification of existing structures and includes illustrated examples of good design practice and photographs of tank failures.
Prevention of tank bottom leakage A guide for the design and repair of foundations and bottoms of vertical, cylindrical, steel storage tanks
EEMUA PUBLICATION 183
Edition 2
ISBN 978 0 85931 183 0
The prevention of ground and ground water pollution from leaking storage tanks containing oil or chemical feedstocks or products is of primary importance, particularly in areas with a large number of storage facilities. Where such facilities are near to rivers and other waterways there is an additional risk of pollution being spread and affecting a wider natural environment. Also, leakage is a financial loss to the owner.
GUIDE FOR THE DESIGN, CONSTRUCTON AND USE OF MOUNDED HORIZONTAL CYLINDRICAL STEEL VESSELS FOR PRESSURISED STORAGE OF LPG AT AMBIENT TEMPERATURES.
EEMUA PUBLICATON No. 190 : 2000 (Ammdt2004)
ISBN 085931 071 X
The integrity of a pressure vessel depends on both its strength and the adequacy of the supporting foundation or structure. For vessels on earth foundations, with their inherent proneness to settlement, this aspect is of greater importance than for those more conventionally supported. For this reason, considerable coverage is given in this guide to soil investigation and foundation design.
SPECIFICATION FOR THE FABRICATION OF FOR OFFSHORE INSTALLATIONS NON-PRIMARY STRUCTURAL STEELWORK.
EEMUA PUBLICATION No 197 : 1999
ISBN O 85931 111 2
Developed by the EEMUA Materials for Offshore Service Technical Committee (now merged with the Materials and Fabrication Committee to form the Materials Technology Committee), this
Specification covers the construction of offshore steel structures for installation primarily within the United Kingdom Continental Shelf. It may also be applied to other geographic areas when so desired by the Purchaser, but account would need to be taken of alternative and/or additional requirements which may be specified by local statutory authorities.
[-] The following 13 users Like malc's post:13 users Like malc's post
  • zrilek, amindoxiti, rami1976, blaze, PinkPant, pedzaquino, gulilero, cace-01, milova, sodapas, monter, Dell_Brett, kasiphonk
